Venting A Range Hood Thru Existing Metal Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-22-2011, 02:23 PM   #1
Question
venting a range hood thru existing metal roof
I have a new Broan QP 130 range hood and wish to vent it to the outside. My house is of metal construction with metal girders, studs, beams etc. and has metal siding and roofing. Ceilings are vaulted with no attic space. My stove is on an inside wall, four feet from an outside wall. Using a magnet, I found a metal stud right in the middle of the current hood. I believe the easiest thing to do is to vent thru the roof which is U panel. I am seeking advice before I start. The local building supply is not well stocked. I will need to order most stuff, like the vent flashing and cap.
mycajah is offline   Reply With Quote
Old 03-22-2011, 02:57 PM   #2
Go big. Our house has a metal roof, and the roofer was afraid of putting too big a hole through it. So the 8" duct connects to a 4" hole with a stupid little flapper valve. As a result, the hood doesn't work nearly as well as it used to with the larger hole it went through before the new roof went on.
pyper is offline   Reply With Quote
Attaching a shed roof to an existing roof. JMcLaughlin856 Building & Construction 2 03-13-2011 10:25 PM
Range Hood venting bket HVAC 4 02-19-2011 08:12 AM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 08:44 PM
new range hood with existing cabinets cook Carpentry 6 01-26-2010 02:09 PM
Metal roof vs asphalt shingle roof Bob_T Roofing/Siding 1 06-20-2009 06:51 PM
