Venting Problem Needs Solution. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-25-2011, 04:35 PM   #1
venting problem needs solution.
My house has a ridge vent and continuous soffit vents running the full length of the house on the front and about half way on the back (There was a room addition put on the back of the house which merged with the existing roof). The new addition has no attic space so I don't think I can tie into the newer roof's attic to compensate for the loss of soffit vent at the back of the house. Any suggestions to vent the "soffit-less" part of the roof? Thanks.
jverge is offline   Reply With Quote
Old 12-25-2011, 07:55 PM   #2
Rewards Points: 252
Where are you located? Do you get a lot of snow?
shazapple is offline   Reply With Quote
Old 12-25-2011, 08:00 PM   #3
Rewards Points: 13,458
Why not just add soffit vents to that area?
Old 12-26-2011, 03:57 PM   #4
I live in MD outside of DC. Normally we don't get too much snow.
Old 12-26-2011, 07:08 PM   #5
chb70's Avatar
Can you post a couple pictures.
chb70 is offline   Reply With Quote
Old 12-26-2011, 07:30 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,150
Venting may not accomplish anything depending on how the addition was insulated.
Need to know more about the structure to make proper recommendations.
Old 12-27-2011, 09:39 AM   #7
I will take some pictures and post them. In the meantime, here is a diagram of the roof showing the current vents.
The original structure is shown in blue and the addition in orange (This is not to scale). The addition was constructed by a previous owner so I don't know much about the construction. The addition is tied into the original roof. I do not remember if the addition has a ridge vent on it (I will check that when I take pictures but I don't think it does). The soffits have the perforated vinyl siding material but I cannot verify if its just decorative to match the original house's soffit or are true soffit vents. There is no attic space above the addition. I believe it is just sheetrock, insulation and then roof. In the attic of the original structure where the roof meets the addition I can see the wall of the addition in the attic and fiberglass insulation. There is no access to the addition from the attic so I'm sure I can't rely on the soffit vents of the addition (even if they are vents) to compensate for the loss of the soffit vent in the original structure.
Thanks.
Old 12-27-2011, 08:18 PM   #8
You may not actually have a problem, or it may be worse than you think.
Ridge venting typically is rated at 18 NFVA per lineal foot.
If you can figure out the NFVA rating of your continuous soffit, you can figure out how much intake ventilation you have.
If you have more intake ventilation than exhaust, even with the "loss" of intake at the addition, you are still in good shape.
... as long as your soffit intake isn't blocked by insulation at the top of the wall
... and as long as there are rafter baffles in the cathedral ceiling of the addition.
Last edited by Gary in WA; 12-27-2011 at 11:12 PM. Reason: removed web link- belongs under sign. line.
Double-A is offline   Reply With Quote
Tags
vent
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
Tankless water heater venting problem kchopper Plumbing 1 08-17-2009 03:32 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Chimney has simple problem - complicated solution Leah Frances General DIY Discussions 6 03-18-2008 04:52 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
