Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-24-2010, 01:36 PM   #1
venting from mobile home through new metal roof
I want to put a metal roof onto my existing mobile home roof. My gas furance vent is not tall enough to go through the new metal roof. I have been told that a mobile home gas furnace vent has both the intake and out-take in the same design; a pipe within a pipe, that is why my pipe is 12 inches in diameter. I believe it is this type of exhaust & intake system.
I have also been told that I only need to bring the exhaust pipe through the new metal roof and that the intake pipe can draw its air from inside the roof. I have end vents on both sides of my mobile home allowing it to draw enough air. My question is; is this feasible and is this safe. I would not want to have it catch fire.
jeanmoon is offline   Reply With Quote
Old 07-26-2010, 12:09 AM   #2
I don't know about mobile home exhaust vents. But if you're correct (pipe-within-a-pipe), then I would recommend you have both pipes thru the roof. Having a hidden (blind) intake doesn't seem smart from a maintenance or accessiblility standpoint.
Also, I think mobile homes can only have 1 layer of roofing. So plan on a tear-off. I've seen old mobile homes with multiple layers, and the roof sags between the rafters with the extra weight. Looks terrible.
Note: I am not a roofer.
-Pjackso is offline   Reply With Quote
Old 07-27-2010, 09:39 PM   #3
You are right about making acessibility very difficult. I was trying to cut the size of the vent down going through the new roof from 10 or 12 inches to either 4 or 6 inches.
The new roof will be built as a truss, and I am planning to use it to help hold the ceiling in place. I also have 2x6 walls to support the weight. Thanks for your thoughts. It helps.
not venting a metal roof penny0322 Roofing 6 03-25-2011 06:39 PM
Metal Roof Estimate supton Off Topic 5 04-17-2010 04:08 PM
Mobile home with covered deck macboney Roofing 1 10-29-2009 10:21 PM
Flat roof venting question vendejp Roofing 8 07-17-2008 04:45 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 10:40 AM
