-   -   venting from mobile home through new metal roof (http://www.diychatroom.com/f9/venting-mobile-home-through-new-metal-roof-76977/)
jeanmoon 07-24-2010 12:36 PM
I want to put a metal roof onto my existing mobile home roof. My gas furance vent is not tall enough to go through the new metal roof. I have been told that a mobile home gas furnace vent has both the intake and out-take in the same design; a pipe within a pipe, that is why my pipe is 12 inches in diameter. I believe it is this type of exhaust & intake system.
I have also been told that I only need to bring the exhaust pipe through the new metal roof and that the intake pipe can draw its air from inside the roof. I have end vents on both sides of my mobile home allowing it to draw enough air. My question is; is this feasible and is this safe. I would not want to have it catch fire.
-Pjackso 07-25-2010 11:09 PM
I don't know about mobile home exhaust vents. But if you're correct (pipe-within-a-pipe), then I would recommend you have both pipes thru the roof. Having a hidden (blind) intake doesn't seem smart from a maintenance or accessiblility standpoint.
Also, I think mobile homes can only have 1 layer of roofing. So plan on a tear-off. I've seen old mobile homes with multiple layers, and the roof sags between the rafters with the extra weight. Looks terrible.
Note: I am not a roofer.
jeanmoon 07-27-2010 08:39 PM
You are right about making acessibility very difficult. I was trying to cut the size of the vent down going through the new roof from 10 or 12 inches to either 4 or 6 inches.
The new roof will be built as a truss, and I am planning to use it to help hold the ceiling in place. I also have 2x6 walls to support the weight. Thanks for your thoughts. It helps.
BrowneBearLLC 04-30-2015 01:23 PM
Trailer roofs are not like stick built homes and can only have one layer
1985gt 04-30-2015 01:24 PM
I hope you weren't to late in telling him that. I'm sure its a 10 year project...
BrowneBearLLC 04-30-2015 01:25 PM
Also, do not rely on attic space for air going to the burner.I have found so many trailers that have plugged up roof vents I could not count them on one hand.
1985gt 04-30-2015 01:30 PM
So 6 in total?
Windows on Wash 04-30-2015 05:23 PM
:laughing::laughing::laughing:
OldNBroken 05-01-2015 08:53 AM
:whistling2: :whistling2: :whistling2:
................. :wheelchair:
