Venting Metal Roofs - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-07-2011, 04:22 PM   #1
venting metal roofs
I have shingles on my house and I had a construction crew put a metal roof on. They put the metal roof on over the shingles with nothing inbetween, i have heard you should either put some form of material or wood strips inbetween the two. Which is the best way? Also they didn't put any vents on and last winter (our first with the metal roof) we had quite abit of moisture in the attached garage. Do we need to put in vents? If so which ones?
mschreifels@net is offline   Reply With Quote
Old 12-07-2011, 08:47 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,850
You do not need to vent over deck although it is a good option in cooling dominated climates.
They should have installed some sort of slip layer between your old shingles and the new metal roof.
What is the venting of the attic like right now and where was the moisture in the attached garage?
A picture is very helpful in these cases.
I&W around pipes and valley metal fastening diyroofer Roofing/Siding 0 09-12-2011 06:39 PM
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 06:39 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 02:03 PM
Vast overpricing of metal roofs ? Texaspoorboy Roofing/Siding 5 03-16-2008 12:14 PM
