Venting A Hip Roof With Exposed Rafters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-09-2011, 09:13 PM   #1
Venting a hip roof with exposed rafters
Hi all,
I am currently in the process of purchasing my first house. It has a hip roof and exposed rafters. The home inspector told me that the attic could use more ventilation. It already has a couple of exhaust vents but there are no intake vents.
From my reading, it seems that with the lack of a proper soffit, my only option would be to cut holes between the rafters. Some people drill holes and then staple some screening, but I was wondering if rectangular soffit/undereave vents (such as these ones: http://www.airvent.com/homeowner/pro...ndereave.shtml )could be used for a cleaner look. They would be installed vertically instead of horizontally. Is this a problem? Do I have to install them on all 4 sides? If I could avoid installing some on the street side I think it would be even cleaner.
What type of wind baffle would you recommend to prevent the insulation from blocking the vent?
Thanks!
Eudaemonic is offline   Reply With Quote
Old 02-10-2011, 09:16 AM   #2
Residential Roofer
Slyfox's Avatar
The slotted method is far more sufficient than drilled holes.
I would make absolute certain there's no structural issues before you do either.
In the case in which you have to go through lumber that plays a direct role in supporting the tails/ends of those exposed rafters you would need to drill holes instead of cutting slots.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Microwave roof venting grandmalois Roofing/Siding 18 10-10-2011 06:28 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Proper venting of new roof on attached garage jlatulippe Roofing/Siding 1 11-26-2009 04:24 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing/Siding 3 03-27-2007 01:16 AM
