Venting A Hip Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-12-2005, 08:57 AM   #1
Question
Venting a hip roof?
Have a hip roof on a 90-something year old house. I want to vent the small attic in some way due to the heat that is trapped in there throughout the summer months. There are no soffit vents, I am assuming because of the small space where the rafters, roof, and walls meet. Any suggestions?
gimpy026 is offline   Reply With Quote
Old 08-13-2005, 12:01 AM   #2
I used this http://www.owenscorning.com/around/v...sure_ridge.asp
when I built my workshop along with soffit vents. I don't know about retrofitting into an existing roof, though.
I would have to think that a vent fan would be somewhat unsightly in a house that old. Remember you will need venting at the eave to get air to flow thru your attic.
Neil_K is offline   Reply With Quote
Old 08-13-2005, 12:27 AM   #3
Contractor
I'm suprised that Grumpy isn't here yet. He'll solve your problems if some others don't beat him to the punch.
Teetorbilt is offline   Reply With Quote
Old 08-15-2005, 04:58 PM   #4
Here are a couple options for you.
Kevin K is offline   Reply With Quote
Old 08-15-2005, 11:14 PM   #5
Contractor
90 yrs. old and no problems, why mess with it? To save on some cooling costs, a radient barrier might be an alternative.
Old 08-19-2005, 10:33 PM   #6
Commercial Roofing
AaronB's Avatar
Still need intake.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 08-22-2005, 08:19 PM   #7
Grumpy's Avatar
Rewards Points: 508
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
FHA, or is it HUG recommends 1 square foot of ventilation fo every 300 square feet of attic space. This can come in the form of intake and exhaust, Ie 150 in 150 out. The best veniltaiotn system have an intake equal to or greater of the exhaust.
I do NOT vent my hips due to potential wind driven penetration of moisture and snow but Aaron said to me once he has vented hips before, with no problem.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 02-05-2008, 06:51 PM   #8
Hip Roof/exposed rafter tails
Help! I have a 50x52 structure with a hip roof and exposed rafter tails. Practically no ridge and no soffits. What is going to be the best way for me to get the proper ventilation under this metal roof? I have already planned to use a whole house fan inside the home which makes it even more important that I get good exhaust, as well as intake. ideas?
Girla is offline   Reply With Quote
Old 02-06-2008, 10:32 AM   #9
If you are reroofing the structure, then you can install the Smart Vent made by DCI Products Inc. I have used it extensively when intake ventilation options are otherwise null and void, but if the metal panels are already in place, then you might have to consider cutting vent holes into the top plate on the walls and installing screening over the holes.
The metal panel manufacturer may have their recommendation for a specific brand of ridge vent product.
With the addition of the whole house fan, intake ventilation will be even more of a necessity to go along with a balanced amount of exhaust ventilation.
Ed
Ed the Roofer is offline   Reply With Quote
roof venting cathedral ceiling Pete H Roofing/Siding 16 09-29-2009 03:26 AM
Venting Dryer Through Roof Thirdeye General DIY Discussions 1 03-04-2007 12:06 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
