Venting A Flat Roof With Parapets - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-17-2008, 06:32 PM   #1
venting a flat roof with parapets
I'm insulating a flat roof from the inside. I've dropped the ceiling and will have about 4" of airspace between the roof sheeting and insulation. Each joist cavity will join a wall stud cavity which extends up past the top of the joists to provide framing for the parapet. Should I cut a horizontal slot in the parapet across each of the stud cavities on both ends of the roof, add some screening and then flash an awning over the top? The other choice seems to be to put a row of roof vents on both sides but that's 17 vents on each side!
timconnerey is offline   Reply With Quote
Old 03-17-2008, 06:59 PM   #2
tonyBagadonuts's Avatar
Rewards Points: 29
Looks like you pretty much listed your options here.
tonyBagadonuts is offline   Reply With Quote
Old 03-22-2008, 10:29 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
if the parapet has shingles on the exterior,you`ll have room to put a large gable louvgre inside the parapet wall,dependent on height above roofline(flat),or you can try to drill holes thru the parapet top,put cobra vent,and the cap with metal parapet flashing---without some soffit vents,you won`t get much airflow--you also should look at the quality(r)of your insulation,if it`s low or a cathedral style ceiling,you may be better off not venting the flat roof at all--would be fine with 2"isocyanurate on deck,then install the roofing,and this will keep the condensation from the bottom of the roofing
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Flat roof venting question vendejp Roofing/Siding 8 07-17-2008 04:45 PM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 09:41 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
