Venting An Existing Shed Type Roof. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-17-2010, 10:03 AM   #1
Rewards Points: 150
venting an existing shed type roof.
I have a shed type lean-to roof that attaches to the back of my house. The room has always been there but I want to finish it now and insulate the rafters and sheetrock. The house was built in the 30s with solid soffit. I can vent them and leave the insulation gaps but how do i vent the top?? I have seen the hal ridge vent style vents but I would really rather not get into that if avoidable.
I was thinking I could just put a passive vent on the roof but will that allow proper flow. The roof slopes 2 in 12 and the main roof overhangs the top about 18 inches.
Also the rafters are sealed in between at the wall so after venting the soffit would drilling some holes in the boards between the rafters be enough flow??? also the same issue at the top. How do i get that side to side air flow?
Its a 90 sq ft room with 3 exterior wall and its just a laundry room so the heat in winter will never be more than 60 at the most and no AC in summer.
I really appreciate it.
organick is offline   Reply With Quote
Old 12-17-2010, 05:57 PM   #2
I have had good success with the variety of ventilation products manufactured by DCI Products, Inc., called Smart Vent.
Here is the shed roof application link:
http://www.dciproducts.com/html/shedroof.htm
And here is the link to the Rafter Vent, if you are able to remove the decking at a time of re-roofing.
http://www.dciproducts.com/html/raftervent.htm
Ed
Ed the Roofer is offline   Reply With Quote
Old 12-17-2010, 09:05 PM   #3
Rewards Points: 150
Thanks for the info ed. I have seen the smart vent before. I am not re-roofing this at all right now though. Just finishing the inside and need to vent the roof. I am drywalling onto the rafters. I want to do what I can now.
Roof over existing roof Rammertime Roofing/Siding 9 05-25-2011 08:09 AM
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 05:33 AM
Shed roof stubits Roofing/Siding 1 07-14-2009 07:48 PM
Roof Venting Issue, crawlspace supton Roofing/Siding 1 11-12-2008 06:44 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
