-   -   Venting dryer/bathroom (http://www.diychatroom.com/f9/venting-dryer-bathroom-67265/)
syogod 03-21-2010 11:01 AM
I recently purchased a very old home and am slowly working on remodeling/fixing all the problems.
The previous owners were simply venting the dryer into the laundry room, and the bathroom had no ventilation at all.
The section of the house that these two rooms are in is a 1 story, with a flat tar roof, with a metal sloped roof over that.
My dilemma lies in how should I go about venting this? I thought about possible venting it down through the basement (unfinished), and out a basement window. Besides that, my only other option I believe is to go up through the flat tar roof, and up another 7 feet or so and through the metal. If I go this route, what's the best way to go through the tar roof? I'm unsure where any of the joists are, nor what else is between the ceiling of the rooms and the tar roof.
syogod 03-25-2010 05:45 PM
anyone?
Scuba_Dave 03-25-2010 07:09 PM
With a metal roof I'd go out the side of the house
The dryer w/vent near the bottom going thru the basement is an option
But I would not go thru a window
Bathroom install an overhead fan & go out the side
syogod 03-25-2010 07:11 PM
That leads to problem #2...it's a brick/stone house...no idea how easy it will be to go through the side of that.
Scuba_Dave 03-25-2010 07:25 PM
Bathroom ventilation is not required if there is a window
But I put a fan in no matter what
You can go thru brick...I have not done it
But Holmes on Homes they used a hole saw that went thru brick
Might be able to rent one
So brick covers everything ?
No soffit area near the roof ?
syogod 03-26-2010 08:41 AM
The laundry room isn't on an exterior wall, so I'm thinking through the basement is the best bet on that.
The bathroom is on an exterior, but the soffit will be hard to utilize (kinda hard to explain, I'll take pictures when I get home from work).
AaronB 03-27-2010 11:46 PM
Going through the roof is not a big deal. Hire a roofer to make sure it is all done properly.
seeyou 03-28-2010 07:04 AM
I'm gonna get on the "call a roofer" bandwagon on this one. Through the roof is likely the best option, but I couldn't really advise exactly how to accomplish it w/o some pics.
Alex Damgaard 04-03-2010 12:21 AM
When you install the dryer duct do not use a flexible vent. Use a single wall duct that is not connected with screws (catches lint). You want to minimize the number of elbows and distance if possible. If you vent through a wall keep away from any air conditioning condenser (lint will gum up the coil). If you do punch through the roof make sure that the vent has an unscreened opening with a damper. (A screened vent will catch the lint and present a fire hazard over time).
AaronB 04-04-2010 03:43 AM
In addition, I suggest designing the vent and shaft in order to be able to access it for easy cleaning.
