Venting A Conventionally Framed Cathedral Ceiling With A Reverse Gable - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-27-2010, 08:53 PM   #1
Angry
venting a conventionally framed cathedral ceiling with a reverse gable
pls. help I have a cathedral ceiling 10/12 pitch with a large reverse gable also 10/12 pitch. I am having shingle problems (certainteed architectural 30 yr.) the shingles are curling and falling apart only on this side of the roof ie. poor ventilation. The conventional framing does not allow for air flow on a great portion of this side of the roof. I do have continuous soffit vents and plenty of rige vent (the good stuff) however from the valleys out it can't get air (boxed in). I thought of reframing with firring strips and new ply over the existing and using an edge vent but i have heard of ice dam water leaks with this type of venting. I live in the Detroit, Michigan area (cold winters and Snow). pls help thks. Dan
HEY SO WHATS THE PROBLEM NO ONE OUT THERE HAS ANY IDEAS ON A FIX? GUESS THIS SITE ISN'T WHAT I THOUGHT 146 LOOKS NOT ONE SUGGETION! I WAS UNDER THE ASSUMPTION SOME OF YOU WERE PROFESSIONAL ROOFERS OR BUILDERS DIY MUST MEAN haven"t DONE IT YET!
1960danm is offline   Reply With Quote
roof venting cathedral ceiling Pete H Roofing/Siding 16 09-29-2009 03:26 AM
prep work for a cathedral ceiling smallcrpt Carpentry 3 01-17-2007 08:57 PM
Cathedral ceiling ventilation dpreznik Roofing/Siding 2 10-31-2006 11:18 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
Cathedral ceiling insulation Unregistered Building & Construction 2 09-17-2005 01:21 AM
