Venting Bathrooms Out The Soffits? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-21-2010, 10:16 AM   #1
Rewards Points: 392
Venting Bathrooms out the soffits?
I currently have two bathrooms combining and venting through the roof. This is leaky and goes through many 90s to do this.
I was wondering if I can vent it out the soffit instead?
Basically I have a one story house and the vent would have to be cut into the 2x6 at the soffit. I'd put a appliance vent with a flap and grate to direct the air downwards..
This would prevent the several 90s and it would prevent the chance for the flashing to leak around the roof.
Is it OK to vent a bathroom out a soffit? I don't see this done very often, I see them vented out the side of houses, but I don't notice it venting out the soffit. Is there some code that doesn't like moisture pooling in that space or whatever?
Please see my quick illustration for an example of what I'm talking about.
zootjeff is offline   Reply With Quote
Old 03-21-2010, 05:54 PM   #2
Residential Roofer
Slyfox's Avatar
In my area code allows it to be vented out the soffits.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 03-21-2010, 06:41 PM   #3
The only issue with the soffit is if there are soffit vents there for the roof
Then the moisture can be pulled up into that area & cause problems
Old 03-22-2010, 04:13 PM   #4
Rewards Points: 392
So would you suggest I not do this?
Old 03-22-2010, 05:06 PM   #5
Newbie Bill
Rewards Points: 522
Like Dave said, if you have soffit vents, some of the moisture will end up back in your attic. Ask This Old House did a piece on that very topic. Lots of mold and rot on the underside of the roofing from this very issue.
When you say your current set up is very leaky, do you mean water leaks on the roof, or the venting is leaking moist air into the attic?
I would say all the homes in my area are vented through the roof. I know of very few people who have problems with a leaky roof where these vents are installed. So yes, it can be an issue, but if done properly, it usually isn't.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 03-22-2010, 05:15 PM   #6
If you have soffit vents in this area I would not do it
If it was just a bathroom with a toilet - no problem
But once you add moisture from a shower not a good idea
Venting ponch37300 Plumbing 41 02-23-2013 10:37 PM
Too Much Soffit Venting? atw58 Roofing/Siding 2 05-16-2009 08:19 AM
Soffit venting vs. DCI Smart Vent JDPII Roofing/Siding 1 02-28-2009 08:42 PM
Wooden Tongue & Groove Soffits Beverlyb Roofing/Siding 2 08-30-2008 10:31 AM
Soffits - dealing with my design blunder shtoink Building & Construction 7 08-01-2008 08:01 PM
