Venting Bathroom Fans - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-28-2010, 08:15 PM   #1
Shade Tree Mechanic
I've installed bathroom fans before, and have always vented to the side of the house. My new place has two full baths, back to back. The overhang on the house is literally four feet on the outside wall of the bathrooms.
Seems like the way to go is through the roof. Is there any ducting product that would allow me to only penetrate the roof once for both vents without allowing back flow into either bath?
Any advice on materials, or methods would be appreciated.
Thanks in advance.
ignition is offline   Reply With Quote
Old 03-01-2010, 04:37 PM   #2
I just put two new fans in (Nutone), and both had flapper valves on them to prevent air from escaping when the fan is off. It looks to me like the same flappers would prevent back pressure from one fan escaping from the other.
houseinthewoods is offline   Reply With Quote
Old 03-06-2010, 11:54 PM   #3
Rewards Points: 183
http://www.fantech.net/bathroom.htm
Look about halfway down that page. You can use one fan motor mounted in the attic with two grills.
paul100 is offline   Reply With Quote
Need advice on two adjoining bathroom fans HautingLu HVAC 2 09-08-2009 09:09 PM
Bathroom fans, heating, etc lofar Remodeling 4 07-08-2009 12:44 PM
Venting new bathroom fans gillm HVAC 2 06-04-2009 10:36 PM
Venting up vs out for bathroom, kitchen pcampbell HVAC 12 11-15-2008 10:02 AM
Attic venting - Ridge vents or fans? jebmke Roofing/Siding 16 07-03-2008 11:03 AM
