Ventilation In The Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-21-2011, 07:59 AM   #1
ventilation in the attic
what is the purpose of putting mour vents between the spacers in the attic?
finn is offline   Reply With Quote
Old 10-21-2011, 08:43 AM   #2
Rewards Points: 150
If vents are added correctly which means having an equal amount of ventilation at the highest point of the roof(peak) and the lowest point of the roof(soffit). This creates what is called the "chimney effect" as hot air rises and exits the vents at the peak of the roof it pulls cooler air through the soffits, cooling the attic and removing moisture.
To figure proper amount of ventilation.
Minimum-1 sq.ft. of ventilation (NFA) for every 300 sq.ft. of attic space. 50% of this number goes to the peak and 50% to the soffit. I like to use a ratio of 1/150.
josall is offline   Reply With Quote
Attic ventilation - Have enough? Am I correct that there isn't much? darlingm Insulation 9 09-08-2011 04:11 PM
Attic ventilation project AKH Roofing/Siding 3 07-15-2011 07:13 AM
Air sealing, ventilation, and attic insulation project-need advice Badfish740 General DIY Discussions 4 06-01-2011 06:48 AM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
Old Basement venting & Attic Ventilation RyanPaq HVAC 0 11-16-2010 04:10 PM
