Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-15-2010, 09:02 AM   #1
Ventilation
I have an older 1950's era contemporary house in the mid-Atlantic part of the country. It has a sloped 3/12 pitched roof that is tar and pea gravel covered. The interior of the house has cathedral ceilings with exposed tongue and groove wood boards. From what I know the tar and gravel roof is over a layer of unknown insulation and there is a vapor barrier of some sort directly over the exposed tongue and groove boards. There is no attic. I have lived there for two years and the roof is probably 4-6 years old.
We had a very cold and snowy winter this year. On two different occasions, I had instances of water dripping inside the house from the tongue and groove board ceilings in several different locations. There was no snow on the roof at the time and it was not raining. The last instance was a day in February. The dripping has not occurred since. I see no signs of any moisture. I have had no dripping when there was melting snow on the roof or rain. This has never happened in past years either.
A roofing contractor inspected the roof and told me that everything looked fine and he didnít see any bad spots in the roof. He indicated that I may need vents?
I have one vent in a laundry room/furnace room that is directly above the furnace that vents outside.
Any recommendations on what to do next?
pschmitt is offline   Reply With Quote
Old 04-15-2010, 11:01 AM   #2
Commercial Roofing
AaronB's Avatar
Sounds like you're having condensation issues. I say this because you stated no snow, no rain, and its dripping, and no dripping with snow melt.
I say find the source of moisture, and fix it, as well as add insulation to the roof.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-16-2010, 04:32 PM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Sounds like a tough/impossible one to vent. From the info given, I second "more insulation".
seeyou is offline   Reply With Quote
Tags
condensation , flat roof , ventilation
Proper Balanced Ventilation? echase Roofing/Siding 8 04-21-2010 04:44 PM
Light, Ventilation, and Heating code requirements sarbear HVAC 12 11-30-2009 11:10 AM
attic ventilation lou1968 Roofing/Siding 5 05-31-2009 09:33 PM
Ventilation System icedams Roofing/Siding 9 02-25-2009 07:57 AM
Ice dam and soffet ventilation jvanostrand Roofing/Siding 3 02-11-2009 03:44 PM
