Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-19-2012, 12:16 PM   #1
ventilation
can you use cobra ridge vent in a mobile home with cathedral cieling
tdlawson123 is offline   Reply With Quote
Old 02-20-2012, 09:29 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
...for venting the ridge?
I see no reason why not.
If this is a DIY project, spend the extra bucks and get a quality rigid ridge vent (i.e. GAF or Air Vent II).
Old 02-22-2012, 11:06 AM   #3
Stroudsburg Roofer
PAHome's Avatar
Ridge Vent
Ridge vents are part of a roof system. You will need to check if you have soffit vents for air intake and some sort of baffles behind the insulation in the ceilings to allow the air to flow from the soffits to the ridge. If you have not soffit vents and baffles than the ridge vent really isn't doing much, but it cant hurt the roof.
www.pa-homeimprovements.com
"your local roofing experts"
570-484-ROOF
PAHome is offline   Reply With Quote
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 12:19 PM
Proper Balanced Ventilation? echase Roofing/Siding 8 04-21-2010 05:44 PM
Light, Ventilation, and Heating code requirements sarbear HVAC 12 11-30-2009 12:10 PM
