Vented Drip Edge Problem - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-23-2011, 12:28 AM   #1
Vented Drip Edge problem
About three years ago I had a new roof installed with ridge vent and vented drip edge. I decided on vented drip edge over soffit vents because of ease of installation. Unfortunately I made a mistake of not thinking it through or consulting with pros. I live in upstate NY and during the winter the vented drip edge is completely blocked by ice building up in the gutters and my roof gets NO ventilation. I should have chosen soffit ventilation.
But at this point I wonder if I could fix existing condition by installing heater cables on the roof edge and gutters. My thinking is that if I could keep vented drip edge open for intake air the system should work. Am I wrong?
Thanks a lot
vadifey is offline   Reply With Quote
Old 08-31-2011, 10:12 AM   #2
mem
Rewards Points: 156
Put in the soffit vents now. They cost nothing to operate.
mem is offline   Reply With Quote
Old 09-08-2011, 04:34 PM   #3
vents . . .
Do vents, it is the correct way to fix it. Besides, why spend $ year after year on heat to counter a design issue.
BCIDallas is offline   Reply With Quote
Old 09-08-2011, 04:46 PM   #4
Rewards Points: 252
Where is the ice coming from? If it is from the weather then yes, soffits are probably the best way to go. Do you have adequate insulation in your attic space? Other than vented drip edge do you have any other ventilation?
shazapple is offline   Reply With Quote
Old 08-25-2012, 10:15 PM   #5
pnac66@gmail.com
Is ventilated drip edge application ok to use in temperature ranges below 15 degrees?
pnac66 is offline   Reply With Quote
Old 08-29-2012, 04:20 PM   #6
Bombastic Idiot
notmrjohn's Avatar
Go with soffit vents. I'd never heard of vented drip edge. After googling I thot, " what a stupid idea." No ice build up down here, but a frog drowner of a storm can over flow the gutters, with splashes into the vent, definatly sucking humidity into attic. And humidity is one of the things, some say the main thing, your trying to vent out.
notmrjohn is offline   Reply With Quote
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing/Siding 6 07-13-2015 10:04 AM
Vented drip edge AAA Roofing/Siding 4 07-18-2011 12:26 AM
Overhanging Drip Edge Columbus Roofing/Siding 11 03-29-2011 10:32 PM
Gutter and drip edge beagles Roofing/Siding 11 10-13-2009 03:55 PM
fascia and drip edge glassman General DIY Discussions 3 10-02-2006 07:39 PM
