-   -   Vent Stack Flashing (http://www.diychatroom.com/f9/vent-stack-flashing-77623/)
thompy31 07-31-2010 11:57 PM
Vent Stack Flashing
I have a cast iron vent stack that exits the first floor roof (over a bathroom addition) and is anchored to the side of my house where it extends past the second floor roof. The pipe itself is ~15 tall. The roofing cement around the base is a mess and I need to re-flash the vent before I get a leak.
How can I flash this? I can't use traditional vent flashing because I can't slide the flange down the length of the pipe (it's attached to the side of my house).
Is there a product that can wrap around the base without leaking or should I just re-patch the base with roofing cement?
Any advice would be greatly appreciated!
- Mike
seeyou 08-01-2010 03:59 AM
- Mike
Do a search for "electrical weatherhead flashing". There's a 2 piece flashing available that may work if there's enough space between the pipe and the wall.
thompy31 08-01-2010 10:17 PM
Re: Vent Stack Flashing
Thanks so much! A search for electrical weatherhead flashing led me to a company that sells retrofit flashing that should work perfectly. $15 for the flashing an an hour's work should do the trick!
Thanks again!
