Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-26-2010, 09:51 PM   #16
Vent Stack
Originally Posted by JakAHearts View Post
Actually, the 3' pvc is too large to fit through the hole and when I opened the hole to the larger opening, the hole was much too large but 4" pvc was not also too big to fit through the new hole.
Shane
You can heat up the opening and stretch it over your pipe,done it a few times..
johnk is offline   Reply With Quote
vent stack leak GeorgeE Plumbing 1 04-18-2010 04:26 PM
Limit on turns in Vent stack? HooKooDooKu Plumbing 4 03-19-2010 11:03 AM
can stack vent turn 90 degrees? hohadcr Plumbing 6 03-16-2010 07:45 AM
Vent stack is on other side of basement... Feretich Plumbing 5 02-12-2010 02:13 AM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
