Vent Stack - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-22-2010, 03:32 PM   #1
Knows everything but that
Rewards Points: 150
Vent Stack
So as in another post, im remodeling my upstairs bathroom. The drain/vent stack goes straight out the roof. However, its not really held up by anything other than the pressure from the pipe below. It looks sealed from the outside but there is some signs of wood rot around the opening. Anyway, should the pipe be able to be lifted straight out of the roof or should it be secured in some way? Also, should I look into resealing it or is it normal for, after 30 years, some signs of moisture to be present in the wood. THanks!
Shane
JakAHearts is offline   Reply With Quote
Old 04-22-2010, 07:33 PM   #2
Rewards Points: 150
Vent stack/main drain loose
So I asked this over in the roofing section but perhaps it was the wrong spot because Ive had lots of views but no replies.
Shane
Old 04-22-2010, 08:35 PM   #3
Rewards Points: 292
I can answer part of this question. All signe of moisture or wood rot should be addressed regardless of age. It will not get better, only worse.
Jim F is offline   Reply With Quote
Old 04-22-2010, 09:59 PM   #4
DIY staff
Rewards Points: 7,174
You failed to mention what type of pipe--iron or PVC---
With PVC a vent stack boot is all that is used to keep out the rain--Kind of looks like a square brimmed rubber hat with a hole in the top. If there is signs of water leaking see of the rubber is cracked or the 'brim' has pulled up from the shingles.
With iron--the stack boot is made of lead--it is slipped over the iron stack --laced into the shingles and the top of the lead sleeve is folded into the top of the vent.
---Mike---
Old 04-23-2010, 08:14 AM   #5
Rewards Points: 150
---Mike---
Thanks Mike. The pipe is iron currently. I dont mind it being PVC since the iron one is terrible rusty. How har would it be to convert to PVC? The portion that is iron is only about 6 feet long before they updated the plumbing to PVC.
Shane
Old 04-23-2010, 05:05 PM   #6
Commercial Roofing
AaronB's Avatar
I agree with Jim.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-23-2010, 06:48 PM   #7
DIY staff
You will need to go up on the roof to install the boot. That is the most difficult part--you will need to remove the old lead boot--carefully lift the shingles- pull the nails holding the old boot--
install the new pvc vent pipe and install the new rubber boot.
If the shingles are old and brittle--this can be a bit risky--if your shingles are relatively new it's a fairly simple task.
---Mike---
Old 04-23-2010, 07:22 PM   #8
DIY staff
Moderators---please merge this post with his other one on the same subject--Thanks -Mike-
JakAHearts (04-23-2010)
Old 04-23-2010, 09:22 PM   #9
Commercial Roofing
AaronB's Avatar
What section would that be in?
Old 04-23-2010, 09:48 PM   #10
Rewards Points: 150
Its in plumbing. Thanks!
Old 04-23-2010, 10:47 PM   #11
Commercial Roofing
AaronB's Avatar
Well why not let it be here, too, since we are talking about the roof now, too?
Old 04-24-2010, 08:51 AM   #12
Military Mom of 4
Snav's Avatar
If you replaced it with PVC you'd have to cut the pipe somewhere (under the house, in the wall - depends on whether you're on a slab or not, duplex, etc) and use flexible coupling to attach it. Like so: http://www.fernco.com/plumbing/flexible-couplings
These flexible couplings are made to join old gauge pipe to new gauge pipe. Different materials have different diameters - or older pipes are smaller/bigger than newer pipes of the same material for a variety of reasons.
If, however, this is the only pipe in your house that is metal - and everything else is modern pvc - then you can remove the metal completely and replace the whole length with matching pvc using pvc cement.
(note - the clamps on the couplings can be tightened with a screwdriver or a socket - it's easier to use a socket as how most of these are only cut for a flat head)
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 04-26-2010, 09:38 AM   #13
Rewards Points: 150
Im having trouble finding a vent stack seal that will fit for 3" PVC. Are there specific ones for PVC sizes or do I have to cut it myself? Thanks
Shane
Old 04-26-2010, 07:57 PM   #14
Military Mom of 4
Snav's Avatar
Can you find it for 4"?
You can put an expander on it (3" to 4") and cap that - a bit hob nob but it'll work just the same.
Old 04-26-2010, 08:46 PM   #15
Rewards Points: 150
Actually, the 3' pvc is too large to fit through the hole and when I opened the hole to the larger opening, the hole was much too large but 4" pvc was not also too big to fit through the new hole.
Shane
vent stack leak GeorgeE Plumbing 1 04-18-2010 03:26 PM
Limit on turns in Vent stack? HooKooDooKu Plumbing 4 03-19-2010 10:03 AM
can stack vent turn 90 degrees? hohadcr Plumbing 6 03-16-2010 06:45 AM
Vent stack is on other side of basement... Feretich Plumbing 5 02-12-2010 01:13 AM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
