Vent Pipe Boots -holes Eaten In Them - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-03-2009, 03:34 PM   #1
Vent pipe boots -holes eaten in them
Something is making holes in the sides and tops of the lead plumbing vent pipes on our roof. They need replacing again after about 1 1/2 years because each time something apparently gnaws holes in the pipes - big holes - about 2 to 3 inches high and a third of the way around the pipe. The holes are close to the bottom of the pipes. Is there anything we can do to prevent this? What could be doing this - squirrels, birds?
N. Duval is offline   Reply With Quote
Old 02-03-2009, 04:13 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Squirrels. Replace them and put a few wraps of hardware cloth around them. THe PVC ones are only good for 6-10 years.
tinner666 is offline   Reply With Quote
Old 02-03-2009, 07:14 PM   #3
Yes, squirrels eat those things for some reason.
Not the brightest rodent on the planet.
If you don't know what Timmer was referring to, you could use tightly meshed chicken wire.
Ed
Ed the Roofer is offline   Reply With Quote
Old 02-03-2009, 07:52 PM   #4
old timer
You could use a copper pipe flashing.
dmc@RCR is offline   Reply With Quote
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
