Vent Pipe - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-16-2012, 06:16 PM   #1
Rewards Points: 528
vent pipe
What area of the vent pipe usually gives way to leaking 1st(after many years )?
hidden1 is offline   Reply With Quote
Old 11-16-2012, 07:47 PM   #2
Rewards Points: 2,212
flashing. either where the flashing and pipe meet or the flashing and the roof.
mae-ling is offline   Reply With Quote
Old 11-16-2012, 10:07 PM   #3
Rewards Points: 13,736
Why you asking?
http://www.bing.com/images/search?q=...11C21E&first=1
Old 11-16-2012, 10:29 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
Most often times the boot becomes UV degraded and breaks down.
That is an overwhelming majority of the failures.
Old 11-16-2012, 10:46 PM   #5
Rewards Points: 528
Just sealed mine and wanted to know.
Old 11-16-2012, 10:51 PM   #6
Sealed it
Hope you do not mean you used something like roofing tar or silicone on it.
Not going to work!!
Old 11-17-2012, 10:10 AM   #7
Rewards Points: 528
over the nails at the bottom of it
Old 11-18-2012, 07:12 AM   #8
That is fine but that is not where 99.99% of the leaks on vent boots come from.
using section of pipe for both drain and vent amakarevic Plumbing 6 05-11-2011 12:20 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Hot Water Heater Improper Vent Pipe Danger fritzycat1 Plumbing 2 07-27-2009 10:34 AM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
