Vent Pipe - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-13-2011, 02:10 PM   #1
vent pipe
I have a vent pipe that comes through the roof that has a rubber section to it that has a hole. This is nailed to the roof by having a metal base to it and is partially covered by the roofing shingles. Is there some way to replace this rubber section, or perhaps covering over the damaged rubber, without removing and replacing the whole piece?
Dibbledge is offline   Reply With Quote
Old 04-13-2011, 10:30 PM   #2
In a little over my head
Rewards Points: 706
That's the flashing, or boot. Easy to replace. they have 'em at Home Depot. Carefully lift the shingles and slide the old one up, new one down. There're even a few Youtube videos on it.
ratherbefishing is offline   Reply With Quote
Rerouting vent, changing pipe type Lockeset Plumbing 11 11-09-2010 05:47 AM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Water dripping from vent pipe Rosy_55 Plumbing 4 01-07-2010 09:35 AM
Hot Water Heater Improper Vent Pipe Danger fritzycat1 Plumbing 2 07-27-2009 10:34 AM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
