Vent Flashing Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-25-2009, 03:21 AM   #1
Rewards Points: 28
Unhappy
Vent flashing question
Hello,
I just had a new roof installed and the vent flashing on the slope side has exposed roofing nails holding it down. It seems like all that I have read says this should never be done. Some of the flashing is nailed and exposed on the down slope side. I thought this can cause leaks thru the nail hole. Any advice or information sources to know waht is right would be appreciated.
Thanks,
J
Jwhitman is offline   Reply With Quote
Old 08-25-2009, 07:13 AM   #2
Residential Roofer
Slyfox's Avatar
Vent flashing's commonly have exposed nails at the bottom end to prevent driven winds from getting under the flashing.
They should have been covered in caulking upon completion.
Assuming they are in flush there is no immediate concern, but you will want to get them caulked.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 08-25-2009, 07:15 AM   #3
I use Ice & water shield around vents/penetrations
This is supposed to seal around nails - & works very well
I put a dab of sealer/tar under the flashing - then nail
The amount of water that can leak thru is very minimal
You could also get more from longer nails & water vapor condensing on the exposed nail under the sheathing as Temps change
Not a roofer, but I'd think they should be sealed with something
To Vent or not to Vent, that is the question debster Roofing/Siding 5 08-10-2009 04:48 PM
Proper way to install half round dormer vent? Git Roofing/Siding 12 07-31-2009 05:33 PM
plumbing vent flashing on metal roof??? red86yota Roofing/Siding 14 02-09-2009 11:40 AM
Carrier Furnace Vent Motor Question ajay12 HVAC 1 12-23-2008 10:23 PM
Thru wall vent question phillyexplorer HVAC 5 10-11-2008 09:50 PM
