Vent Cap Size Ok For Dryer? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-27-2010, 11:27 AM   #1
Vent cap size ok for dryer?
When I first bought my house there was no vent for the dryer. There was a vent cap in the ceiling that I am now using for my dryer. It seems to work fine but I've noticed on some houses there is a larger vent cap on the roof (presumably for the dryer). Mine looks something like this....
http://www.amazon.com/Broan-Nutone-6.../dp/B000BQW6LE
Is there anything dangerous or intrinsically wrong with using a smaller vent cap for the dryer?
PS it throws a little lint onto my roof but this is something I can deal with. The vent piping is semi-rigid and there is only about 8' from the dryer to the vent.
chazman113 is offline   Reply With Quote
Old 07-27-2010, 05:48 PM   #2
RST
DIY Homeowner
Rewards Points: 150
I'm pretty sure I installed that exact cap for my dryer last summer. I ran a new outlet straight up and out the roof (~10). (The original piping was over 20 long and severely clogged.) Seems to be working fine, I'm pleased. Can't comment on how well it works with long-term use though.
RST
RST is offline   Reply With Quote
Old 07-27-2010, 06:43 PM   #3
Registered User
Rewards Points: 5,236
4" is required. That Broan 636 has a bird screen inside which will stop the lint and build-up, interfering with the self-closing door. http://www.broan.com/ImageLibrary/br...s/99041930.pdf
"The vent piping is semi-rigid and there is only about 8' from the dryer to the vent." ---- so it is a slope ceiling above?
The new transition ducting is heavy foil covered- 8' maximum: http://www.appliance411.com/faq/dryer-vent-length.shtml
Be safe, Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
chazman113 (07-27-2010), RST (07-27-2010)
Old 07-27-2010, 09:49 PM   #4
Rewards Points: 1,088
I believe there's a sticker on the flashing that says to remove the screen if used as a dryer vent. It can be done with a flat head screwdriver.
handy man88 is offline   Reply With Quote
The Following 2 Users Say Thank You to handy man88 For This Useful Post:
Gary in WA (07-27-2010), RST (07-27-2010)
Old 07-27-2010, 11:39 PM   #5
RST
DIY Homeowner
Rewards Points: 150
Thanks guys -- next time I am on the roof, I will check mine to be sure I removed the screen when I installed it!
Open Bean no Attic Bath Vent cdrusds HVAC 0 10-08-2009 04:46 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
To Vent or not to Vent, that is the question debster Roofing/Siding 5 08-10-2009 05:48 PM
Foundation crawl space vent size problem Constant Improvement Building & Construction 15 01-15-2009 06:07 PM
