Vent Cap Material - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-26-2010, 12:01 AM   #1
Rewards Points: 117
Vent cap material
Hi All,
Searched the forum, but can't seem to find an answer to this:
What's the best material for vent caps and vent pipe boots? Plastic or metal?
Cheers
Chris
spiragui is offline   Reply With Quote
Old 07-27-2010, 04:03 PM   #2
RST
DIY Homeowner
Rewards Points: 150
Bump.
Saw a discussion on another forum that box metal attic vents were preferable to those made of plastic. Don't think that's your exact question though.
RST
RST is offline   Reply With Quote
Old 07-27-2010, 04:09 PM   #3
the Musigician
DangerMouse's Avatar
google: ecap vent caps
They make a real sweet (and inexpensive) pvc 'mushroom' cap that glues on with standard pvc glue.
I was just searching the same thing this morning!
DM
Old 08-20-2010, 09:37 AM   #4
the Musigician
I got my ecap yesterday.
It took a few days longer than I had expected, but it would seem this guy is just starting out with this product. (perhaps I should buy some stock?)
It looks like it will work out just fine!
DM
Old 08-20-2010, 08:16 PM   #5
Remodeling Contractor
I think he is talking about pipe boots (pipe flashing) and the actual roof vents. Metal. Plastic has a tendency to deteriorate relatively quickly on a roof. Also, after the plastic starts to weather, it will crack extremely easily.
eisert is offline   Reply With Quote
Old 09-03-2010, 12:39 PM   #6
Rewards Points: 117
Vent material
Hi Guys,
Yeah, I was referring to the pipe boots and roof vents. I ended up going with metal, thankfully! The old ones were half plastic, half yellowjacket-nest.
Not sure what it is about my roof, but it's a yellowjacket magnet. I opened one of the shingle bundles last night, and a whole bunch of them flew out. Kind of difficult to run away when you're tethered to a rooftop (although instinctively I did at least try), but luckily it was late in the evening and they were all a bit dozy!
Cheers
Chris
Old 09-03-2010, 02:13 PM   #7
Doing This Way Too Long
Rewards Points: 532
Yes, you were correct in going with metal. And don't think you have cornered the market on yellowjackets. We buy hornet spray by the case.
OldNBroken is offline   Reply With Quote
Old 09-03-2010, 05:01 PM   #8
Rewards Points: 117
Nailgun in one hand, Raid in the other. That's how I roll!
At least the seasoned pros arm themselves with bug spray too. You guys probably don't run screaming like a sissy when they swarm you though...
When I tore off the ridge on my garage there was a huge nest underneath, which resulted in me running the length of the garage roof (7 in 12 pitch) and jumping from the roof, through some fir trees, into my neighbours yard to escape the angry swarm. What made it worse was the fir tree was infested with orb weavers, so I ended up crawling with spiders instead. I guess at least they don't sting. I should have got someone to video me replacing the roof, as there have been some comedy moments for sure.
Cheers
Chris
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Newbie: Soffit NFA calculation + what material for vent? Tranch Roofing/Siding 5 07-19-2009 06:43 PM
dryer vent connecting material Alan HVAC 7 08-31-2008 06:42 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
