#1 |
Velux skylight curb -- PT lumber or regular?
i need to build a simple 2x6 frame to act as curb for my Velux VCM 2222 skylight. there will be flashing around it as well as the protective tape that came with the flashing kit. i was wondering if i should use PT lumber or regular. i heard that PT lumber can corrode aluminum flashing but then again, there will be that tape in between, i believe.
thanks |
#2 |
Doing This Way Too Long
No need for PT as it is 100% sealed from the elements by the flashing. And, yes, it can corrode the aluminum but that is secondary. We never use PT on any curbs.
| The Following User Says Thank You to OldNBroken For This Useful Post: | amakarevic (05-30-2012) |
#3 |
Pro Slate Roofer
Regular wood like the rest of the house.
Frank To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to tinner666 For This Useful Post: | amakarevic (05-30-2012) |
#4 |
Exterior Construction
+1
PT lumber may also negatively interact with metal components of the flashing or fasteners. Standard lumber is proper.
| The Following User Says Thank You to Windows on Wash For This Useful Post: | amakarevic (05-30-2012) |
| Tags |
skylight ![]() |
| Display Modes | |
| Velux skylight opening | amakarevic | Building & Construction | 8 | 05-16-2012 04:05 PM |
| painting regular SPF lumber for weather exposure | amakarevic | Painting | 2 | 02-20-2012 07:06 PM |
| Velux Skylights - Curb Vs. Deck Mounted | SimpleFix | Building & Construction | 3 | 10-23-2011 03:55 PM |
| Need Hex Bolt for Older Velux Skylight | xquercus | Roofing/Siding | 0 | 05-26-2010 02:19 PM |
| Velux skylight install with 10 degree slope and corrugated tin roofing | oliverbutthead | Roofing/Siding | 8 | 07-06-2008 10:23 PM |
