Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-22-2010, 10:55 AM   #1
vaulted ceiling venting question
Since each pair of rafter creates there own void or individual air space can you vent sideways through the rafters into the sofit area. I don't want to drill upwards through the metal roof for each void. if you can vent sideways what size hole would be required for a 16 ft long 8.5 inches deep 14.5 inches wide area
brutherb is offline   Reply With Quote
Old 09-30-2010, 08:25 AM   #2
This is tough to answer - I face almost the same dilemna as you.
Yes you can drill holes in your rafters - but only a little and within careful guidelines.
These guidelines are meant more for drilling holes for electric wires etc. and may not be applicable to the more numerous holes needed to enable cross venting.
You at least have a pitched roof which would allow for a ridge vent - why not that?
Another way that I'm considering is make a 3/4 inch gap below the rafters with cross strapped furr strips and placing the insulation layer/ceiling below that.. The downside is that insulation has to be removed from the rafter bays. The new location of the insulation/ceiling below the furring drops the ceiling down.
rodeo is offline   Reply With Quote
Old 08-11-2011, 07:33 PM   #3
sophit vents installed from the sophit cavity through to the ridge vent allow air to flow through the cold zone (you need a cold zone or it will condinsate)insulate up to it and vapour barrier.
user123303 is offline   Reply With Quote
Crown moulding with a vaulted ceiling? cstrat Carpentry 34 06-17-2011 07:51 PM
two fold question on roof venting and insulation brutherb Roofing 0 09-20-2010 07:43 PM
VERY Quick Ceiling Fan install question! Fox Electrical 10 07-02-2010 05:03 PM
vaulted ceiling lighting sgtrock Building & Construction 0 05-02-2010 07:27 PM
Insulating Vaulted Ceiling cibula11 Building & Construction 11 01-31-2010 09:48 AM
