Vapor Barrier Debate (in My Head) - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-01-2011, 12:47 AM   #1
Rewards Points: 956
Unhappy
Vapor Barrier Debate (in my head)
So after having talked to the contractor and reading threads on this forum I am conflicted about this topic. Is it better to install a vapor barrier with open cell spray foam or no? The contractor says no but I am reading here that it's a good idea! I am probably overthinking it but I can't decide.
federer is offline   Reply With Quote
Old 06-02-2011, 08:46 AM   #2
Your roof is unvented - if I recall.
That being so, then dont VB over the foam.
You will be creating a double vapor barrier
which will eventually rot the woodwork. Especially if its OSB decking.
Some moisture does migrate through open cell.
It may/ may not be OK. It depends in part on the moisture load you are throwing at it. If you can keep your winter humidity levels low like around 35%, you'll be fine. But many times humidity is higher and can be difficult/expensive to lower enough.
Closed cell might be the better option. It will create a double vapor barrier which means any moisture that finds its way through can rot the decking but its much less of a problem. Even if your decking rots, the closed cell foam is rigid enough to essentially become the structure on its own.
rodeo is offline   Reply With Quote
Old 06-03-2011, 12:34 AM   #3
Rewards Points: 956
thanks for the input. yes I am sorry my roof is unvented. that was what I was considering-doing closed cell. except that if the roof does leak I will have no way of knowing until the wood is rotted away. hence why I am using open cell....but you are saying the risk of that is not that great then?
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 10:00 AM
Handheld shower in addition to fixed head OnTheGo Plumbing 4 03-25-2010 12:31 AM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 01:59 PM
Shower Head Breaking Off mbarnes Plumbing 3 01-11-2009 07:38 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 12:23 PM
