Valleys In New Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-09-2014, 12:50 PM   #1
valleys in new roof
3 yrs ago I had my roof replaced, and after noticing valleys in it, the contractor came and walked on it and says the wood under the shingles is pulp! The shingles are so tight, he couldn't even lift one to check under it.
What could cause this to happen? At the time of the job, everything was replaced, wood, vents, soffits, fascia, fan, gutters and insulation. Help!
sharong is offline   Reply With Quote
Old 05-09-2014, 01:31 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
Beats me. The sun will seal the shingles which is good. With good ventilation the wood should be ok unless you have termites or something is eating it or water is getting under shingles.
Robpo is offline   Reply With Quote
Old 05-09-2014, 01:33 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Lot of possibilities, possibly a poor install allowing leakage on the roof, or major moisture issues in the attic. Pics would help, although sometimes these things can be difficult to narrow down without seeing in person.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 05-09-2014, 03:23 PM   #4
Rewards Points: 13,732
Looked in the attic yet?
Old 05-09-2014, 03:27 PM   #5
Checked for fungus from lack of proper venting?
Did they use H clips between the rafters or trusses?
rerplace roof on 200 year old house newroof Roofing/Siding 7 11-24-2013 05:23 PM
help! strange horizontal bubbles on new roof dfwnewroof Roofing/Siding 49 11-17-2012 06:46 AM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
