Valley Weave - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-08-2007, 08:29 AM   #1
valley weave
I have a leak from the asphalt weave in the valley area.
I really do not want to rip up the area but would like to apply alternate fix.
typhoon55 is offline   Reply With Quote
Old 03-08-2007, 12:10 PM   #2
bucket of roofing cement.
roofwiz74 is offline   Reply With Quote
Old 03-08-2007, 12:10 PM   #3
Commercial Roofing
AaronB's Avatar
In that case, good luck to you.
Quick fixes usually end up costing you more in the long run.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-08-2007, 12:18 PM   #4
Rewards Points: 790
Try to find the exact place of the leak. Most likely if it is in the valley, there may be a nail causing this to happen. You are not suppose to nail in the valley, but this may have happened. If you can pinpoint it, get some clear geocel and place a dab on the nail head. If it's more than a few spots, it might be worth reroofing.
cibula11 is offline   Reply With Quote
Old 03-08-2007, 12:36 PM   #5
tear it out and loose the weave.use a waterproof underlayment.reshingle.no leak.
climb up on the roof look for anything, slap some crap on it,fix the leak?yes,slap yourself on the back.no,climb back up and slap more crap on there.keep doing this until you can see it a mile away then call a good roofer to come fix it and he'll charge you extra just to work in the mess that was made.lol j/k.
Old 03-08-2007, 12:54 PM   #6
Is this leak from rain or ice dam?
redline is offline   Reply With Quote
Old 03-09-2007, 01:00 PM   #7
it is a leak from rain - until the snow clears out i cannot tell if possible nail heads- it is a small section so will try to pinpoint leak
Old 03-09-2007, 04:26 PM   #8
Commercial Roofing
AaronB's Avatar
Un fortunately, I have found that anything other than dis-assembling the valley, finding the source of leakage, and repairing accordingly is nothing better than a shot in the dark. How much valley is it? Could be a few hundred dollar repair.
Valley Shower Faucet lost Plumbing 17 01-27-2008 12:54 PM
What kind of flashing Malcolm Roofing/Siding 4 06-20-2007 01:59 PM
Electrical service too near valley of roof? adamselene Roofing/Siding 3 05-11-2007 07:56 AM
Roof over porch in double valley doitall Building & Construction 1 04-25-2006 11:33 AM
