Valley Vs Weaving? Which Is Better? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-11-2013, 04:11 PM   #1
Valley vs Weaving? Which is better?
Here in Ohio, some contractors prefer one over the other. what are the pros and cons of valleys vs weaving from a home owners perspective?
what are the pro's and con's from a contractors perspective?
eugierom is offline   Reply With Quote
Old 04-11-2013, 08:48 PM   #2
Rewards Points: 13,458
In my own opion if done correctly both will work fine.
Just depends on what type look your going for.
If someone does not take the time to make sure the open valley is wider at the bottom then the top and uses paper thin flashing then it's going to fail.
Old 04-11-2013, 10:35 PM   #3
Rewards Points: 626
Both have their place. Both have problems if not done right. On my home I have a weave. On my brothers Home we both work Constrction he has wide flashing and valleys. personl prefrence. is what it comes down to. Just have to do it right.
Nailbags is offline   Reply With Quote
Old 04-12-2013, 08:02 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
Both will work and have applications. What is the vegetation around the home like?
Old 04-12-2013, 08:22 AM   #5
One small tree and that's it. Why?
Old 04-12-2013, 09:08 AM   #6
Roofmaster
Rewards Points: 2,172
Neither, Closed Cut.
Old 04-12-2013, 09:43 AM   #7
And the answer is...D. None of the above.
How to roof this valley section? kooguy Roofing/Siding 2 07-22-2012 06:21 PM
Need input on this open valley technique jogr Roofing/Siding 12 11-01-2011 06:49 AM
I&W around pipes and valley metal fastening diyroofer Roofing/Siding 0 09-12-2011 05:39 PM
Valley Weaving Justin08 Roofing/Siding 7 12-09-2008 06:28 AM
Electrical service too near valley of roof? adamselene Roofing/Siding 3 05-11-2007 07:56 AM
