Valley Flashing Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-09-2014, 08:22 PM   #1
Valley Flashing question
Hi,
Without getting into a debate as to "Why would I"..Are there any professional roofers that can tell me:When flashing a valley using Ice & water membrane AND aluminum flashing.....
What goes on FIRST?.....The ice & water then the flashing.....OR the flashing then the ice and water??
I've searched and have found a 50-50 split (practically) on which one gets applied first.
I'm guessing ice & water shield...then aluminum flashing.(Just guessing)
Also...do you nail through the flashing or just catch the edge of the flashing with the head of the nail....allowing movement / expansion,etc.
Thanks for any input from those in-the-know.
Thanks!
jodejr is offline   Reply With Quote
Old 08-09-2014, 09:20 PM   #2
Rewards Points: 440
Just think about the properties of the products and go from there. So, ice and water is meant to stick to the base surface, adheres strongly, and seals after nails are driven through. Aluminum or copper flashing does not adhere, does not seal, and is meant to be protection to layers that deteriorate quickly when hit with UV light or are relatively easily damaged.
So, ice and water, flashing, shingles. The ice and water will seal all nail holes that go through it. And i nail the flashing...all well S drip edge, etc. just don't blow it in too tightly. Ron
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
AndyWRS (08-09-2014)
Old 08-09-2014, 09:24 PM   #3
Metal Roofing
Rewards Points: 600
I&W then valley
AndyWRS is offline   Reply With Quote
Old 08-09-2014, 10:24 PM   #4
Hey..Just wanted to thank you both for the quick replies. My guess was correct after all.
Good to know for sure. Thanks for the correct procedure info on the instal.
Tags
valley flashing
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Question for step flashing donaramu Roofing/Siding 1 09-17-2012 04:15 PM
Roof Valley Question wmarazita Roofing/Siding 13 09-03-2012 09:04 PM
Valley with a short flashing rjwrightohio Roofing/Siding 7 10-05-2011 06:18 PM
Valley flashing, how wide should I go? KarlJay Roofing/Siding 5 10-05-2010 08:09 PM
