Valley Flashing Peeling - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-15-2015, 03:07 PM   #1
Rewards Points: 6
Valley flashing peeling
I had a new roof installed about 4 years ago. Within the first year, the valley flashing started to peel. The manufacturer, supplier, and installer all blamed each other and so I go screwed...typical. The supplier did send somebody out once to paint the flashing but it only last about a year. Does anybody have any suggestions on a permanent fix. The shingles are no longer available so they cannot remove the shingles and replace the flashing. I hope somebody has a solution. Thanks
Fairway30 is offline   Reply With Quote
Old 02-15-2015, 04:36 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,292
So the paint on the metal is pealing?
Old 02-15-2015, 04:44 PM   #3
Rewards Points: 6
Yes, the paint on the flashing has peeled or flaked off in many places. It has happened on most of the valley flashing. Not something that should happen.
Old 02-15-2015, 04:55 PM   #4
Doesn't happen that often to be honest if you use a quality material.
How brittle are the shingles?
Old 02-15-2015, 11:05 PM   #5
Got a picture.?
ron45 is offline   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
roofermann (02-16-2015)
Flashing Peeling Up on New Roof LeakyHawaiiRoof Roofing/Siding 22 10-27-2014 05:44 PM
Valley Flashing question jodejr Roofing/Siding 3 08-09-2014 10:24 PM
Valley flashing with architectural shingles EdfromMaryland Roofing/Siding 3 08-01-2014 03:12 PM
flashing in valley. should it show? greentrees Roofing/Siding 5 10-14-2013 03:21 PM
Roof patch job ok or not? daluu Roofing/Siding 8 11-07-2012 08:56 AM
