Using A Starter Strip Or Trimmed Shingle - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-20-2013, 12:18 PM   #1
Rewards Points: 280
Using A Starter Strip or Trimmed Shingle
Which do you use when starting asphalt roofing, colored shingle or dedicated starter strip?
I'm being told cutting a colored shingle is better since manufacturers charge more for starter strips. My research shows dedicated starter are cheaper for 100 linear feet vs cutting the tabs off 100 linear feet of colored shingle.
Earnie is offline   Reply With Quote
Old 11-20-2013, 04:05 PM   #2
Rewards Points: 628
Starter strips are cheaper.
Quality wise, on eaves I prefer 3tabs for starter for the increased headlap they afford. Starter strips are nice up rakes.
PatChap is offline   Reply With Quote
Old 11-21-2013, 08:16 AM   #3
roofermann's Avatar
Rewards Points: 401
I concur fully.
roofermann is offline   Reply With Quote
Old 11-21-2013, 04:28 PM   #4
747
registered
747's Avatar
Rewards Points: 534
You don't to waist a nice 30 year for a starter. Just get some stater shingles or some cheap 3 tabs.
747 is offline   Reply With Quote
Old 11-21-2013, 05:32 PM   #5
Rewards Points: 280
Exactly what I'm thinking. Even more so since I'm paying more for the upgraded shingle that are being used as a starter.
While I'm thinking about it, why isn't a rolled starter strip product used? From what I have read about installing the starter, it has to be properly spaced so the starter seams don't line up with the shingle seams. Wouldn't rolling out a continuous starter eliminate the seam issue? Roll out, nail, and it's done. Would work for the rake end also.
Old 11-21-2013, 05:50 PM   #6
Rewards Points: 628
Installing starters is roofing 101.
I think OC makes a rolled starter, though I cant imagine why.
I bet your roofer just wants to use up some of his shingle pile, the pile of shingles next to his shed. Every roofer has one.
Old 11-21-2013, 05:59 PM   #7
ParagonEx's Avatar
Rewards Points: 150
I cannot stand guys who use 3-tabs as starters these days. They're rarely ever installed properly.
Premade starter is better, cheaper and quicker.
ParagonEx is offline   Reply With Quote
Old 11-21-2013, 06:35 PM   #8
roofermann's Avatar
Rewards Points: 401
"waste" vs "waist"
Old 11-23-2013, 12:52 AM   #9
747
registered
747's Avatar
Rewards Points: 534
Originally Posted by roofermann View Post
"waste" vs "waist"
I just read my post. I screwed it up a couple times.
To OP just grab some starter shingles.
The Following User Says Thank You to 747 For This Useful Post:
roofermann (11-23-2013)
Old 11-23-2013, 05:42 PM   #10
Davejss's Avatar
Rewards Points: 740
If someone can't figure out how to use a three tab shingle as a starter they have no business on a roof.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
roofermann (11-24-2013)
Old 11-24-2013, 08:22 PM   #11
ParagonEx's Avatar
Rewards Points: 150
We very rarely tear off roofs where the my cut the tabs of the shingle. Actually, I can only remember one.
Old 11-28-2013, 11:34 AM   #12
Rewards Points: 280
Happy Thanksgiving to all.
Again, my point is, there is a proper tool for every job. Why turn a shingle around if it was designed to be installed the other/correct/tab down way?
If there are less expensive manufacturer designed starter strips, why not use them. I really don't want previous job, mixed color, been laying around next to the shed shingles used on my house.
My house, my money.
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Forgot starter strip when shingling marykirk Roofing/Siding 5 05-31-2012 11:05 AM
No starter strip used on shed roof install? waterskier_erie Roofing/Siding 4 10-31-2011 09:25 PM
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing/Siding 4 11-24-2010 03:05 PM
CertainTeed starter shingle ? MACCC Roofing/Siding 2 04-20-2007 03:26 PM
