#1 |
using recovery board
can i glue down the new rubber onto new osb or plywood? or do i need to use recovery board
#2 |
Shut in w/o Home
If the OSB has been screwed down (rather than nailed), you can adhere directly to it. Your membrane will likely last longer with recovery board, though. Plywood can de-laminate, so it's not a good choice for use w/o recovery board.
| The Following User Says Thank You to seeyou For This Useful Post: | jasserwin (04-05-2011) |
#3 |
Low Slope Roofing
Both are ok to glue to if screwed as said before. It is however better to use a recovery board to protect the EPDM. Also it takes more glue to glue to plywood and even more to OSB then a recovery board.
| Display Modes | |
| Carrier furnace control board - OEM or ICM ? | anku | HVAC | 13 | 10-12-2012 11:50 PM |
| 5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) | LeviDIY | Building & Construction | 9 | 02-09-2010 10:41 PM |
| luxaire/york 33109167000 furnace board replacement | check | HVAC | 18 | 07-13-2009 11:03 AM |
| installing backer board over particle board | bob mac | Flooring | 5 | 06-15-2009 06:01 PM |
| Installing deck ledger board over foam board? | RickT | Building & Construction | 5 | 11-06-2006 11:50 PM |
