Using Manufacturer's Installation Instructions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-06-2013, 10:55 AM   #1
Hi,
Is it okay not to use the Manufacturer's Installation Instructions for Certainteed Cedar Impressions S7 vinyl shingle? If not should the contractor have to rehang it? (eg face nailing and not using the center hole nail at all)
Thank you.
Long Island, NY
JeanAnn is offline   Reply With Quote
Old 11-06-2013, 02:19 PM   #2
kwikfishron's Avatar
Rewards Points: 86
Originally Posted by JeanAnn View Post
Hi,
Thank you.
Long Island, NY
No it's not OK. That center hole is important, nailing there pins the panel so it will expand and contract equally in both directions. Setting the panel to the temperature gauge is also important.
I can't even imagine anyone trying to face nail that stuff, you'd have to pre-drill for every nail. Trying to nail directly through would break the panel every time.
kwikfishron is offline   Reply With Quote
Old 11-06-2013, 02:27 PM   #3
PoleCat's Avatar
Rewards Points: 1,646
[QUOTE=kwikfishron;1263097]............
I can't even imagine anyone trying to face nail that stuff, you'd have to pre-drill for every nail. .........QUOTE]
Not if you are using a nail gun.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is online now   Reply With Quote
Old 11-06-2013, 03:44 PM   #4
The installer face nailed the last row of shingles at the top and the whole top row now has a wave to it. The installer said they did not have to use the manufacturer's directions and use the center nail technique. What to do now?
Old 11-06-2013, 03:46 PM   #5
Rewards Points: 768
Well, typically an installer can do what they want. If they don't use the manufacturer's installation method, it will usually void the warranty provided by the manufacturer. If you (I assume the homeowner) is not satisfied with the job, talk to the installer.
cibula11 is offline   Reply With Quote
Old 11-06-2013, 09:56 PM   #6
Rewards Points: 12,840
http://www.certainteed.com/resources/245.pdf
Old 11-07-2013, 12:28 PM   #7
Hi, I know it was incorrectly installed. The installer does not want to redo it. I read the installation manual and watched the videos. The question is what to do now. Thank you, Long Island, NY
Bruce fold and lock installation instructions Dhue127 Flooring 2 06-11-2012 04:22 PM
New Laminate Floor Installation Creaks.... c3uo Flooring 13 07-12-2011 01:43 PM
Questions on proper roofing installation bikepilot Roofing/Siding 22 04-12-2011 10:25 AM
how to avoid condensation in exterior wall when enclosing washer/dryer pemn Remodeling 6 12-01-2010 03:35 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
