Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-16-2009, 12:22 PM   #16
Is using Luan to overlay soffit a good idea?
Originally Posted by ARI001 View Post
It comes down to your budget; if it was my house I would put in aluminum soffit. If your budget is prohibitive to this then follow CCCs advice and cut out the damaged sections and replace.
The budget isn't really an issue, but I don't want to spend the money to redo the entire house when I only have a few problem areas. I also wouldn't like having aluminum soffit on the gables and wood soffit around the rest of the house. I want everything to be the same.
I think if I get it replaced correctly, caulk it, and paint it, the wood should be fine.
ConstantChange is offline   Reply With Quote
Old 10-16-2009, 09:46 PM   #17
Here is a picture of the rear gable. As you can see, it's pretty bad.
Old 10-19-2009, 09:48 AM   #18
I got in touch with a siding contractor and he didn't want to do it unless I wanted to put vinyl on the entire house. Who knew finding someone to replace some soffit would be such a tough job.
Flatscreen over the fireplace? Is this really a good idea? kashimama Home Theater 43 11-20-2011 12:01 AM
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 10 05-14-2011 10:57 PM
SLATWALL storage solution for Garage, Good Idea?... KUIPORNG General Discussion 9 01-29-2008 10:15 PM
Turbine Vents- a good idea? amazer Roofing 5 09-24-2007 09:24 AM
re-using redwood fencing - a good idea? gulleyj Building & Construction 1 08-08-2007 10:40 PM
