#16 |
Useless Ridge Vent?
NEVER question TRG,unless I`m wrong of course(perish the thought)
lol
"If it`s worth doing,It`s worth doing right!!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#17 |
Pro Slate Roofer
Useless Ridge Vent?
Musta been 1/2 asleep. Missed the width post.
Frank To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#18 |
Super Moderator
Useless Ridge Vent?Without knowing which brand of Ridge Vent is being discussed, I looked up the manufacturers specifications for the ridge vent slot opening, even when you come across a wide ridge board. This method I previously suggested would certainly make more sense and be less costly than additionally having to remove or lift up the decking near the ridge and the shingles already attached to the decking, just to place shims under it. TRG, you had me doubting myself for a little while, but I should have known better and stuck to my guns sooner. By the way, how thich of a shim would you feel is necessary to elevate the decking enough to achieve the rated 18" NFVA per lineal foot? My thoughts would seem to indicate shimming the deckin up by 3/4" per side to perform similarly to a total of 1 1/2" wide slot cut on truss construction. Ed Air Vent’s ridge vent installation instructions require the following when cutting the ridge slot. Slot Width: — If it’s ridge board or ridge pole construction, cut 3⁄4" on each side of the pole or board — If it’s truss construction, cut a 1 1⁄2" opening Slot Length — Cut the slot length along the ridgeline 6" from the end wall or hip intersection — Cut the slot 12" from a chimney or an intersecting ridgeline Cutting the Slot Wider Here’s a common question we receive about slot width: Can I cut the slot wider to increase the Net Free Area? Cutting the slot wider will not increase the Net Free Area because the NFA will be restricted to the openings on the ridge vent. For example, ShingleVent II is specified at 18 square inches of NFA per linear foot. If you cut the slot 2" wide (instead of the required 1 1⁄2") it may seem logical that the NFA would increase to 24 square inches per linear foot. However, keep in mind that the air that passes through the wider slot must now pass through the openings in the ridge vent itself. Although the slot is wider, the ridge vent’s openings remain the same. There’s no benefit to cutting a wider slot. A word of caution: There is the potential for weather infiltration if the slot is cut too wide. The vent needs to fully cover the slot to protect the attic from weather infiltration. C A N Y O U N A I L ¡ G U N S H I N G L E V E N T ® I I ? the Ridge Vent Slot Cutting W I D E R I S N O T B E T T E R T I P : The slot width is designed to match the amount of Net Free Area provided by the ridge vent itself. For example, ShingleVent II has openings that total 18 square inches of NFA per linear foot. Over the span of 1 foot, a 11⁄2" slot width equals 18 square inches. Likewise, a 3⁄4" slot on both sides of the ridge board or pole also equals 18 square inches over the span of 1 foot. |
#19 |
Useless Ridge Vent?
seems like you just bolstered my point,I would shim it up a 1/2",so the air would reach the normal cut out,I don`t see where it says to cut it past a 4 1/2"beam to 5 1/2-6",what I see is
the slot to protect the attic from weather infiltration. ( which is one point I made) the Ridge Vent Slot Cutting W I D E R I S N O T B E T T E R T I P : The slot width is designed to match the amount of Net Free Area provided by the ridge vent itself. For example, ShingleVent II has openings that total 18 square inches of NFA per linear foot. Over the span of 1 foot, a 11⁄2" slot width equals 18 square inches. Likewise, a 3⁄4" slot on both sides of the ridge board or pole also equals 18 square inches over the span of 1 foot.(which was the other )
#20 |
Useless Ridge Vent?
so anyway thanks for cutting +pasting to prove what I was saying
#21 |
Super Moderator
Useless Ridge Vent?
There was more in the document, which stated that you would need to add a bead of tri-polymer sealant under the ridge vent.
It does not specify widths of ridge beams, just how far to cut past them when they are in place. On the roof common sense should dictate if youy have to cut too far. The width of the SV II is 14" across including the external baffle, yet they still specify the slot to be cut the same for the SV II-9 and SV II-7, don't they? Whoops, I better go look that up, before I stick my foot in my mouth. I sure hope that nobody heard that last comment. Shhhh! Ed Last edited by Ed the Roofer; 10-22-2007 at 10:50 PM. |
#22 |
Useless Ridge Vent?
remember the cap is only 12",I know about using the sealant
#23 |
Super Moderator
Useless Ridge Vent?
I correct myself.
The width is only 13 3/4" wide including the external baffles. Ed |
| Display Modes | |
| Ridge Vent: width of cut | judym | Roofing/Siding | 12 | 09-09-2012 03:20 AM |
| Another Ridge Vent, Gable vent and soffit question (??) | davco | Roofing/Siding | 2 | 05-01-2007 12:14 AM |
| Ridge vent question | dpreznik | Roofing/Siding | 7 | 04-13-2007 04:03 PM |
| Ridge vent installation cost | Douche | Roofing/Siding | 1 | 07-26-2006 05:59 AM |
| Ridge Vent - Low-pitched roof? | brianp | Roofing/Siding | 2 | 05-08-2006 09:32 PM |
