Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-18-2010, 11:34 AM   #1
unusual roof venting problem
My roof is a single ridge roof 40' long. 6:12 pitch 23' rise. The only overhang is the 2x12 fascia board coming perpendicular from the roof with the bottom of it coming at an angle to the the top couple of inches of soldier bricks which top the outside walls of the house. There is a 1\4 to 1\2 in space between the two for the length of the house front and back . The top floor has vaulted ceilings with a knee wall about 8' in from the outside wall. There was no vent space left between sheet rock and decking and there are no vents on the roof. I'm getting a new roof and my Question is -Can i use a ridge vent and 3-4 low profile roof vents spaced along the knee wall line to alleviate the extreme heat and sometimes condensation on my top floor?
srussell is offline   Reply With Quote
Old 09-18-2010, 12:28 PM   #2
pics would help. but yea you definitely need to work out a ventilation system. what roofing material do you have
federer is offline   Reply With Quote
Old 09-19-2010, 02:21 AM   #3
existing roof is asphalt shingles. Will get pics soon.
Old 09-19-2010, 08:04 AM   #4
Residential Roofer
Slyfox's Avatar
It can/will help some but very little.
To rid yourself of the problem you need to create free flow of air from the knee wall to the peak of the roof.
They actually make intake vents that can be placed in the roof a few feet above your eaves, they'll perform better than box vents.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 09-19-2010, 09:14 PM   #5
what are those called? just intake vents?
Old 09-20-2010, 06:49 AM   #6
I find several kinds of low profile vents some square or round "slant Back", "eyebrow vent". any suggestions? How many would I use for the attic space that runs 40" long and 8'deep on a 6:12 pitch
Old 09-20-2010, 10:49 AM   #7
those seem fine make sure you got good intake vents too
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Venting a Hip Roof?? CrossWorks Roofing 7 04-06-2009 12:56 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Venting roof with no ridge NateHanson Roofing 3 06-17-2008 06:35 PM
Venting Dryer Through Roof Thirdeye General Discussion 1 03-04-2007 12:06 PM
