Unduro Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-26-2012, 12:46 AM   #1
Rewards Points: 12
Unduro roofing
Anybody have any DIY experience with this roofing material?
Building a new small home and am considering using it.
Is it as DIY as the ads say? Does it last? Can you get a good paint job on it?
cer2012 is offline   Reply With Quote
Old 03-26-2012, 05:51 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I've seen it used on a house once. It's a nightmare to flash. I'd look for something else.
seeyou is offline   Reply With Quote
Old 03-26-2012, 11:19 AM   #3
Doing This Way Too Long
Rewards Points: 532
Gotta agree with CU. I've done one years ago and there are far better and easier systems out there.
OldNBroken is offline   Reply With Quote
Old 03-26-2012, 10:47 PM   #4
Rewards Points: 12
My roof will have a 4 in 12 pitch and no flashing, no pipes thru it.
2 sheets will cover ridge to eave.
What were the problems you had besides flashing?
Old 03-26-2012, 11:12 PM   #5
Rewards Points: 532
Flashings are more than half a roofing job. Doesn't need any more wrong to make it a PIA product. Been so long I can't remember many details other than I don't care to do another...and metal is my bread and butter.
It's also exposed fasteners and I don't care at all for any exposed fastener on an occupied structure.
The Following 3 Users Say Thank You to OldNBroken For This Useful Post:
cer2012 (03-27-2012), seeyou (03-27-2012), tinner666 (03-27-2012)
Old 03-27-2012, 12:06 AM   #6
Rewards Points: 12
Unduro is asphalt like shingles.
It does have exposed fasteners with washers.
I doesn't require underlay only purlins. Code inspector approved it. It has a great warranty.
I don't want problems but am on a limited budget and they are light weight.
They are used by the gov and businesses.
I was hoping to find someone that has had this on their roof too.
Thanks for the input.
Any others out there with any knowledge?
Old 03-27-2012, 12:42 AM   #7
Rewards Points: 532
We are talking about Ondura here correct? Looks like corrugated metal? If so, sorry but the one I did is about 90 miles up north so haven't seen it since installed so can't say anything about how it is now.
Old 03-27-2012, 06:50 AM   #8
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
It's recycled material of unknown quality.
Neither does metal.
So is metal. How limited. Can you afford the potential leaks and failure after 7-10 years. Redoing the roof and sheet rock?
Businesses, maybe, gov, I doubt. Gov doesn't like re-doing the roof every 7-10 years.
I can't find my pix of one I inspected over purloins. Sorry.
Just don't walk on it, even on the purloins. The stuff cracks. Your eave and rake details will leave lots to be desired. It's not forgiving like metal and cannot be shaped there either. As for experience, I've turned down every oppertunity I've been offered to apply it.
tinner666 is offline   Reply With Quote
Old 03-27-2012, 11:12 AM   #9
Rewards Points: 12
Can't find anything about it being recycled material. Manufactures these days "tout" the fact they recycle and keep stuff out of landfields.
They are not to be walked on because, like shingles they get soft in the sun and they have the wavy pattern and 1X4 purlins would not hold your weight. Hot shingle tabs can tear if walked on improperly.
Shingles leak too and a roof leak is the hardest to find.
I have a budget of 18k to build my house. Free family labor except for roof. House is still in planning stage and will end up 900-1100sf. I'm retired and need to make this happen.
7 yr from now the inheritants can put a new roof on. I'm 60yr old. Price diff is great between Unduro and shingles.
What about steel roofing over tar paper and OSB decking?
Old 03-27-2012, 03:10 PM   #10
Pro Slate Roofer
tinner666's Avatar
Why not put the steel over purloins? The felt keeps things dry until the steel goes on. After that, it's full of holes and doesn't keep water out.
http://www.albertsroofing.com/Tin%20...to_gallery.htm
Old 03-27-2012, 04:20 PM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,294
Steel can go direct to deck as long as it has a slip layer and your venting is right.
If the venting isn't right and the roof has a bunch of moisture under it, it will sweat and cause issues.
Steel would be the way to go in my book.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 03-27-2012, 06:05 PM   #12
Rewards Points: 532
Ondura must be dirt cheap if it's cheaper than shingles
Old 03-28-2012, 12:49 AM   #13
Rewards Points: 12
Originally Posted by OldNBroken View Post
+2
Mine is a completely new roof. Add the cost of decking and nails, 30# felt and buttons, and shingles and nails, and drip edge and nails, and ridge vent and nails etc and labor of $100 a square verses 1X4 treated and nails, foam end sealer strips and nails, and the weight is low so I could do it myself...yea dirt cheap!
BTW Tar paper would sag between the purlins and the make-up of tar paper SUPPOSEDLY helps seal the nails and acts as a help to prevent moisture from below and a leak from above.
Moisture will ruin a roof deck.
Old 03-28-2012, 07:56 AM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
I have seen in on a house, looks like crap. Might be fine for a barn or shed, on a house- NO WAY!
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
cer2012 (03-28-2012)
Old 03-28-2012, 12:29 PM   #15
Rewards Points: 129
It might be OK for what you want. I looked at a couple of roofs in my area when I was looking for a lightweight solution for our cottage. One shed roof had been penetrated by a small tree branch and was leaking. It seemed flimsy to me, so I went with metal. Do a Google Search on Ondura and Onduline roofing and you will be abel to see a lot of the issues people have had. I wouldn't use it myself.
ptarmigan61 is offline   Reply With Quote
The Following User Says Thank You to ptarmigan61 For This Useful Post:
Tags
roofing , unduro
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Metal roofing questions Axhammer Roofing/Siding 17 08-10-2010 09:10 AM
Multiple Roofing issues on my home. *HELP!* 2bsure Roofing/Siding 4 12-16-2009 09:29 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
