Which Underlayments For Shallow Pitch Tile Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-25-2009, 05:20 PM   #1
Which underlayments for shallow pitch tile roof?
According to the TRI install guide for cold climates, my 3.5:12 roof needs two underlayments. Tiles will be installed on battens.
A peel and stick of at least 40 mils as a base layer is a given and is so budgeted.
What would would you recommend for an "over layer" to protect the peel and stick for the life of the roof? Titanium UDL? 30# felt?
What about reversing the layers....felt then peel and stick in order to reduce the nail penetrations?
The contractor thinks that the peel and stick is more than enough, but I'd feel more comfortable knowing that the deck was overdone.
Thanks.
meltdowndave is offline   Reply With Quote
Old 08-25-2009, 06:14 PM   #2
Residential Roofer
Slyfox's Avatar
Peel & stick first for sure so it can seal to the deck.
I don't see a need for the second underlayment either, especially if you use something of high quality like Grace Ice & Water Shield 'peel & stick'.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 08-25-2009, 11:19 PM   #3
If you live in a region like Arizona or another sun plentiful state, then the HT (High Temperature), version of Grace Ice and Water Shiled "May" be more appropriate.
But, you do not need the added layer of felt paper if the Ice and Water Shield is installed correctly without missing any critical areas.
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-26-2009, 04:43 AM   #4
Thanks, all.
So if we go with only the Grace Ice and Water Shield, I can still reasonably expect to see a full 50 years out of my tile so long as it's properly installed and the flashing done correctly? And, of course, neighborhood kids watch their foul balls...
Old 08-26-2009, 06:07 AM   #5
Residential Roofer
Slyfox's Avatar
Yes you can.
You need to also remember there is no such thing as maintenance free.
Inspect your roof regularly 'pay some one' or do it yourself,
that way you will notice when debris begins to build up in the valley's, along walls and other penetrations and of course the gutters.
A good install and proper maintenance will make even the cheapest of materials last longer, thus it really adds to the life of good materials.
My statement about Grace was probably miss leading, it's not the only ice & water shield on the market that works.
Facebook <> Twitter
Old 08-27-2009, 04:12 PM   #6
Thanks for the info.
We're going with a GAF product. It's a bit on the thin side at 40 mils, so we're going to top it a 30# felt for added insurance. We'll go light on the cap nails and depend on the battens to be the primary means to secure it. That should reduce the number of nails in the deck.
Were we able to swing the Grace product, one layer would have probably been enough.
What pipe flashing do I use on a tile roof? JDM Roofing/Siding 3 05-13-2009 06:58 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 07:25 PM
Slate Tile Roof Cleaning Tampa Florida - Slate Roof Cleaning Using Lift. apple roof cleaning Roofing/Siding 1 12-31-2008 10:01 AM
How much joist can I cut to clear roof pitch jcrack_corn Building & Construction 1 06-24-2008 04:23 AM
How to tie low pitch roof into sides of house OR build up? jcrack_corn Building & Construction 9 06-22-2008 03:38 PM
