Underground Downspout Extensions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-20-2008, 07:55 AM   #1
underground downspout extensions
I am wanting to replace my downspout extensions that currently sit on top of the yard with ones that run underground and would like detailed step by step directions. Thanks for the help. I wasn't sure if this was the right area to post this so let me know if I should post elsewhere.
joshm is offline   Reply With Quote
Old 05-20-2008, 09:37 AM   #2
You can probably find something here http://www.askthebuilder.com/Drainage.shtml
johnk is offline   Reply With Quote
Old 05-20-2008, 08:28 PM   #3
I'm looking at doing the same thing. The only reservation is that I live in MN and it surely will freeze up in the winter and block any melt. I'm researching some way of heating it when I want to unblock it on a warm winter day. ie heat tape on a switch
tidal9 is offline   Reply With Quote
Old 05-20-2008, 09:45 PM   #4
Use PVC Piping schedule 40, (I think thats the right quality).
Get a heavy duty purpose heat tape.
I had to install one once in the roof drain leader pipe for a TGIF Restaurant that ran the pipe inside of an exterior wall, but did not have the wall insulated correctly.
It solved the problem.
Ed
Ed the Roofer is offline   Reply With Quote
New Underground Gas Line steve f Plumbing 20 03-04-2011 08:15 PM
underground code tom b Electrical 8 03-23-2008 10:55 AM
Adding downspout to torchdown roof Grebus Roofing/Siding 8 10-07-2007 09:50 PM
Underground Wiring millipede Electrical 4 11-24-2006 10:00 PM
