Ugly Plywood Soffits - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-20-2009, 07:36 PM   #1
Rewards Points: 101
Bought a 1950 house that has a nice wide overhang on the roof. Sadly the soffits are plywood with metal floor heating-style grates for ventilation. The plywood is sagging and showing some water damage in places. Have just installed a new roof and now the soffits really look ugly. I have access to a lot of cherry wood and wonder if someone has a plan for making wood-slat soffits. I presume they would need to overlap at the edges? and would need to have some holes drilled at intervals for ventilation. Your thoughts appreciated.
akimbo is offline   Reply With Quote
Old 05-20-2009, 09:13 PM   #2
Household Handyman
Rewards Points: 1,408
First observation is that there are no soffit vents. Wood slat soffits are new to me. The issue would be how to fasten wood slats to the rafters? Personally, I would go back with plywood soffits and the appropriate soffit vents. Thanks, David
Old 05-20-2009, 09:32 PM   #3
Why not run a continuous soffit.Cut the slots,install a nice finished wood over the plywood and screw continuous soffit over the new wood.Or make your own out of screen.There is alot of ways to do this and make it look nice.
johnk is offline   Reply With Quote
Old 05-20-2009, 09:35 PM   #4
Rewards Points: 101
Yes there are soffit vents. Black metal ones that look like interior floor vents. Just not seen in those pics. I have seen some nice wood soffits and I have a lot of wood to get rid of so I'll avoid going the plywood or vinyl route if I can. -- famous last words.
Old 05-20-2009, 11:35 PM   #5
Registered User
Rewards Points: 5,216
Here is a good article, go back a few pages:
http://books.google.com/books?id=Z8a...#PRA1-PA616,M1
Notice the vents angle both ways, install next to fascia board.
How to figure NFA when you cut your vents:
http://www.cornerstoneinspectionsdfw...ntilation.html Be safe, G
Old 05-21-2009, 12:22 AM   #6
They manufacture and sell Tongue And Groove Bead Board for Soffits.
The circular vents do not do much par Intake NFVA. A 4.5" Round Diameter only provides aout 3.00 Square Inches of Net Free Air Intake, which would require them to be installed butted right next to each other to provide close to 9 square Inches per Lineal Foot, which is recommended.
You would be better off with 8" x 16" Rectangular Under Eave Vents, which provide 56 Square Inches of NFVA per Vent location installed.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-21-2009, 01:42 AM   #7
Rewards Points: 101
Thanks Ed, Gbar, John K, Thurman, Good ideas and references. Those prefab soffits are looking better all the time.
Old 05-21-2009, 02:31 AM   #8
If you are referring to the Aluminum Soffit Panels, you should install 100% continuous Vented Panels under the eave edge soffits.
For them to properly vent as Intake portals, you will need to also cut out the existing wood soffit material away.
Ed
Old 05-22-2009, 12:42 AM   #9
Have you removed the plywood? I did on my house and exposed this nice overhang with the original attic vents. Sometimes these planks cover up the real ventilation to the attic and that's where your problems start.
jpike3211 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Tiling - Gap in plywood (sub)floor mcg Remodeling 5 01-15-2009 05:21 PM
Wooden Tongue & Groove Soffits Beverlyb Roofing/Siding 2 08-30-2008 11:31 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
