Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-04-2011, 03:20 AM   #1
Tying in Torch down Roofing to EPDM
I want to replace one section of my flat roof with torch down roofing tying into another flat section that has EPDM on it. What are the hazards in doing this? Can this be done safely?
Thank you.
Sherryfr is offline   Reply With Quote
Old 04-04-2011, 09:58 AM   #2
Doing This Way Too Long
Thank you.
Well, let's start with by you replacing it do you mean you will be the one installing it? That would be your first and biggest hazard unless you have proper experience. Second, rubber and asphalt do not mix. You have to create a separation between the two decks.
Peruse a few of the hundreds of previous "torch down" topics on the forum and you will get an idea of opinions about DIY'ers doing torchdown.
OldNBroken is offline   Reply With Quote
Old 04-04-2011, 10:25 PM   #3
No we are not doing it. Just wanted to know how that goes. I didn't think it was compatible. Thanks.
Old 04-05-2011, 10:55 PM   #4
Low Slope Roofing
there is a couple of ways you can do it.
1.) build a divider wall. Depending on roof slope this may or may not work. A simple 2x4 nailed to the deck with a 2x6,8,10 your choice nailed on edge. Flash the Torched side first lap to top of 2x on edge, flash EPDM side last and let it wrap over the top and down the other side 3-4 inchs, cap nail off and put a cap metal on it.
2.) at tie off area on epdm side burry the EPDM under a 2x4 and water stop the heck out of it. then let your torch roof go over the top, making sure not to heat up the rubber. Anchor bar down threw both layers and mastic and membrane the lap. (this is not ideal) but in any case if one side leaks it wont transfer over to the other/new material.
3.) and best option. Use EPDM on the new roof.
1985gt is online now   Reply With Quote
Old 04-06-2011, 07:17 AM   #5
Thank you. Can't do 1 or 2 because of roof drains. Option 3 is good. Or, Option 4 replace all with torch. Have a great day!
Old 04-06-2011, 12:53 PM   #6
Low Slope Roofing
2 you could do but its not ideal, I would go with 3 or 4 or even better tear it all off and hot mop one on there
Old 04-06-2011, 10:14 PM   #7
Commercial Flat Roofing
What he said.
Seriously, Tie ins even when done properly can cause problems.
Leaks!
Talos4 is offline   Reply With Quote
Tying in Torch down Roofing to EPDM Sherryfr Building & Construction 0 04-03-2011 06:53 AM
Advice about EPDM roofing skiposwald Roofing 6 11-02-2010 11:56 AM
torch on roofing rosemaryaclark General Discussion 3 10-21-2009 12:28 PM
EPDM roofing questions zantar Roofing 4 05-03-2009 08:10 PM
Questions about torch down bitumen and epdm rubber? Max1119 Roofing 1 08-11-2008 11:46 PM
