Tying In New Garage Roof To Old Garage Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-12-2012, 02:44 PM   #1
Tying in New Garage roof to old garage roof
I am wanting to add on to my existing garage with the roof of the new garage perpindicular to the old garage. The old garage is 24w' x 22' d . My new garage addition will be 24'd x 40' w. Are there any videos or help books on tying the new gable roof to the old roof? The old garage has no overhang on the front and back and the new garage will have a 1' overhang on front and back. Any help is apprecated. I am a novice here.
brew92 is offline   Reply With Quote
Old 03-12-2012, 03:25 PM   #2
Rewards Points: 252
The company you are buying your trusses from should be able to design this for you.
Why not just remove the roof and trusses off the existing and continue the new trusses onto the old building?
shazapple is offline   Reply With Quote
Old 03-12-2012, 03:51 PM   #3
The trusses run in opposite directions. The new addition will be perpendicular to the old addition trusses.
Old 03-12-2012, 04:15 PM   #4
Rewards Points: 2,212
Have a good lumber yard do this for you. If your pitch is the same on the addition as it is on the existing garage, because your addition is wider then existing where it joins the roof will be higher.
Do a google search.
mae-ling is offline   Reply With Quote
Old 03-12-2012, 06:07 PM   #5
Rewards Points: 252
That's what I'm saying, remove the old trusses and replace them with new so they are all running in the same direction.
Old 03-12-2012, 10:26 PM   #6
firehawkmph's Avatar
Rewards Points: 1,884
You just need to stick in the gable. Looks something like the pics below. Hire an experienced framer to help you set the trusses and stick in the gable. You'll learn the right way to do it and keep from getting hurt in the process.
Mike Hawkins
Tying in New Garage roof to old garage roof-img_20110825_184801.jpg   Tying in New Garage roof to old garage roof-img_20110825_192634.jpg   Tying in New Garage roof to old garage roof-img_20110829_140221.jpg   Tying in New Garage roof to old garage roof-img_20110829_140256.jpg   Tying in New Garage roof to old garage roof-img_20110829_162312.jpg
firehawkmph is offline   Reply With Quote
The Following 2 Users Say Thank You to firehawkmph For This Useful Post:
mae-ling (03-13-2012), Roofmaster417 (03-13-2012)
Old 03-13-2012, 11:04 AM   #7
Exept your new roof will be higher than the old one.
Old 03-13-2012, 11:54 AM   #8
Depends on the pitches of the roofs. If he reduces the pitch on the new one he could have it hit under the ridge of the old one, if the old one has a decent pitch to start with, so he doesn't end up with a shallow pitch on the new one. On the pics I posted, the old garage and the new addition were both 28'. The original roof was 7/12, I made the new one 6.5/12. it hit about a foot under the old ridge and worked out well. If he only has a 4 or 5/12 pitch to start with, I wouldn't do it that way.
Mike Hawkins
The Following User Says Thank You to firehawkmph For This Useful Post:
Old 03-13-2012, 12:49 PM   #9
RFN-4A-LVN
Roofmaster417's Avatar
It would be very easy to clean the gutters though.
Roofmaster417 is offline   Reply With Quote
The Following 2 Users Say Thank You to Roofmaster417 For This Useful Post:
firehawkmph (03-13-2012), mae-ling (03-13-2012)
Old 12-27-2016, 01:41 PM   #10
Rewards Points: 2
Re: Tying in New Garage roof to old garage roof
Mike Hawkins
How are you attaching your shingles on this? Are you using flashing?
aupga is offline   Reply With Quote
Old 12-28-2016, 07:44 AM   #11
Yes I did use flashing in the valleys. I took a roll of 24" wide aluminum foil stock used for siding trim and bent a traditional W shape in the middle of it.
Mike Hawkins
Old 12-30-2016, 06:34 AM   #12
Rewards Points: 730
The attachment point is a new load on the old roof. Since garage may be designed for the lightest load, you need to check that first. That is, the sizes of the rafters, if truss, can they handle the addition? Type of the ridge, beam or not? How is the ceiling span supported-mid post?
carpdad is offline   Reply With Quote
Seal Leaky Garage Roof from Within? Boiler98 Roofing/Siding 4 03-11-2012 04:22 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
garage roof leak Chicago Bill Roofing/Siding 8 05-05-2009 01:07 PM
advice for insul./vent. of garage roof? King Dark Lake Roofing/Siding 3 04-15-2007 01:37 PM
