Tubular Skylight For 60 Deg Pitched Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-14-2011, 11:19 PM   #1
Tubular skylight for 60 deg pitched roof
Hello all,
We have a really steep roof (old, simple-style Victorian house) and would like to put a tubular skylight in. The problem is that I could only find models warranted up to 12:12 pitch, which translates to 45deg. Our roof is around 55-60 deg. Does anybody know a manufacturer that makes and warrants tube skylights for such roofs? Ideally I would like to have something inconspicuous like a flat roof dome that doesn't stick out like a chimney. Thanks a lot, Christoph
Cwienands is offline   Reply With Quote
Old 04-14-2011, 11:54 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
here ya go:
The TMR VELUX SUN TUNNEL skylight installs on roofs with slopes between 15 (3:12) and 60 (20:12).
http://www.skytechomeservices.com/Tu...Skylights.html
Old 04-15-2011, 08:08 AM   #3
Wow, I had checked the Velux tunnels earlier and for whqtever reason I had found specs stating their limit is 12:12. Well, thanks for making me check again :-) They even have a low profile version for 20:12, exactly whqt I wanted.
Thanks again, Christoph
Old 04-15-2011, 08:18 AM   #4
nap
You talking to me?
nap's Avatar
You're welcome
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 02:55 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Shingles on a low pitched roof oatlord Roofing/Siding 2 12-19-2009 08:51 PM
Skylight on a flat roof? mchardo Roofing/Siding 6 02-19-2009 10:12 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
