Trusses Cut 1/2 Inch When Installing Ridge Vent Install - A Concern? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-02-2011, 10:56 PM   #1
Trusses cut 1/2 inch when installing ridge vent install - a concern?
Just had ridge vents installed and our contractor cut thru the top of our roof trusses about 1/2 inch down on one side and 1/4 inch on the other side when installing. Will this affect the intergrity of the roof?
R
Rueben is offline   Reply With Quote
Old 01-03-2011, 09:16 PM   #2
Registered User
Rewards Points: 5,266
No, as it is above the steel truss plate and close to the ends of the top chords. Sleep well......
Gary
Old 01-04-2011, 09:29 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
It won't affect the integrity of your roof but its not good for your trusses, you are able to cut 1/8" - 1/4" ,so its 1/2 right, your contractor should have set his saw prior to cutting, just for the sake of knowing how far back off the ridgeline to he cut to allow for ventilation? But no your roof system should not be affected , but integrity? rest easy knowing that you are just missing 3/4" of your roof support,. More times than not you will be o.k it is just a irresponsible rookie mistake.
Roofmaster417 is offline   Reply With Quote
Old 01-13-2011, 06:40 PM   #4
Thanks for both replies.
To answer the question about how wide is the cut, in most places, the total width is 2.5 to 3 inches. One section of the roof, it is 4 inches.
Old 01-14-2011, 11:30 PM   #5
RFN-4A-LVN
Well you could say he has given you more than you need.? haha, What type of ridge vent did you have installed ?Manufacture ? Style ? And with what was it fastened?
Old 01-15-2011, 02:40 PM   #6
Rewards Points: 1,088
Ok, so what was their response to the goof up?
handy man88 is offline   Reply With Quote
Tags
ridge vent , trusses
ridge vent ugabulldog Roofing/Siding 4 09-28-2010 09:59 AM
low slope ridge vent concern tns1 Roofing/Siding 4 09-11-2010 04:06 PM
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 11:57 AM
Ridge Vent opinions steel1 Roofing/Siding 1 10-16-2008 07:11 AM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 10:57 PM
