Truss Built Patio Roof Cover - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-01-2013, 09:11 PM   #1
Truss built patio roof cover
Hello,
I am planning on building a patio roof cover using trusses. The cover wii be 23 ft from the house and 16 feet wide. My question is can I use joist hangers to attach the two lvl joists to the rim joist of the house or do I need to install a ledger? I wii be supporting the lvl joist with 6 x 6 posts at 11.5 ft and 23 ft from the house
Scott
Musaw17 is offline   Reply With Quote
Old 03-01-2013, 09:18 PM   #2
Rewards Points: 13,694
No picture of the house, no drawings, going to need some more info.
Got your permit yet?
Old 03-01-2013, 09:24 PM   #3
Framing Contractor
Rewards Points: 118
Many times a hanger can be used. At the very least you will need engineering for the beam and the hangers.
sixeightten is offline   Reply With Quote
Old 03-01-2013, 09:38 PM   #4
What kind of engineering are you referring to?
Old 03-02-2013, 10:08 AM   #5
Roofmaster
Rewards Points: 2,210
Aerospace.
Structural, of course. You're kidding right?
Old 03-02-2013, 10:14 AM   #6
Civil Engineer
Rewards Points: 4,762
As noted by others, it is impossible to visualize your plans without a drawing, photo or sketch. There does seem to be some confusion in your post, since you start out saying you are planning to use trusses, then you morph into using lvl joists. I don't know if you plan to support the trusses using the lvls, or you have something else in mind. I also can't tell if you plan to build your own trusses, or plan to use pre-engineered trusses.
patio cover materials and methods amh56 Building & Construction 7 08-12-2016 03:42 PM
New patio cover and/or enclosed patio jcrizzy Building & Construction 9 01-27-2013 11:30 PM
Attached Patio Overhead Roof Gandalf Building & Construction 8 04-19-2010 11:53 AM
2/12 patio cover - shingle? CZSteve Roofing/Siding 2 08-03-2009 12:34 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
