Trouble With Inspector On 12/1 Pitch Roof Saddle! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-04-2012, 10:08 AM   #1
Trouble with inspector on 12/1 pitch roof saddle!
I framed up a saddle over a valley created by an addition I put on my house. The pitch is like a 12/1. I covered the entire saddle with ice shield and shingled over it.
Now the inspector wont approve my rough because code requires a 12/3 pitch over shingles.
What can I cover the shingles with to pass inspection?
vlady88 is offline   Reply With Quote
Old 03-04-2012, 10:12 AM   #2
DIY staff
Rewards Points: 7,174
If 12/3 is required by your inspector---you will need to rebuild it to 12/3
If they accept a flat roof---ask what the town will accept.
I am not a roofer---one will be along shortly----Mike----
Old 03-04-2012, 10:15 AM   #3
MJW
Code is a 2/12 pitch for shingles. The inspector can require more of a pitch though. How about a picture of what you are doing.
MJW is offline   Reply With Quote
The Following User Says Thank You to MJW For This Useful Post:
oh'mike (03-04-2012)
Old 03-04-2012, 10:27 AM   #4
He stated on the Red tag that a 12/3 in required. Maybe in Michigan the code is different.
I can't post a picture, but maybe I can explain it:
I have two gables creating a valley between them. I framed up a triangle saddle in-between with 18ft 2x6's with 1/2 in ply sheating. Ice Shield the entire saddle and shingled over.
It cannot be seen, so don't care what it looks like. Just need to cover the shingles with something so I can pass inspection.
It is water tight already.
Old 03-04-2012, 10:35 AM   #5
DIY staff
Sounds like you need to cover it with a 12/3 saddle---
He said that is what you must do to pass inspection---
I realize that you don't want to hear that---but he has spoken--
You are in a snow area so the pitch might be set but local conditions.
If you wish to find out if you can leave that existing work you will need to get approval from your building department----
Old 03-04-2012, 10:36 AM   #6
Re-building is the last resort.
It is perfectly weather-proof, just looking for an inexpensive fix. The code requires a 3/12 over shingles, not metal or tar. Just looking for a loop hole so I can proceed to insulation.........
Old 03-04-2012, 10:41 AM   #7
DIY staff
A roofer will see this post and offer a suggestion on the best method to water proof a flat roof---
But you will still need to get approval from the building department before you waste time and money and have that fail,also.
Old 03-04-2012, 10:44 AM   #8
All he has on the inspection sheet is : "A minimum 3/12 pitch is required for all areas of shingled roofs."
Maybe I will have to check code for metal/rolled/tar.................
The Following User Says Thank You to vlady88 For This Useful Post:
Old 03-04-2012, 10:46 AM   #9
I have a 1/12 or maybe a 2/12 pitch now, but good call, I will have to check with the building department!
I was hoping someone would know what to do.............
Old 03-04-2012, 10:52 AM   #10
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Why not peel the shingles off, add 1/2" or 1" ISO instulation and .060 reinforced EPDM. I've seen sevral DIY EPDM's that come out fine. Just follow the directions and have patience.
If you're going to glue it, don't even bother with the cheap .045. It doesn't roll into glue well. And only lasts a few years.
tinner666 is offline   Reply With Quote
Old 03-04-2012, 11:07 AM   #11
DIY staff
Laymans terms?
Old 03-04-2012, 11:18 AM   #12
Rewards Points: 14,000
No company would ever warrenty shingles on that low a slope no matter what you lay under them.
Even most standing seam companys would not suggest it.
EPDM as suggested is the way to go as suggested, and all the shingles will also need to go, there is nothing that can just be laid over them and have it work.
Old 03-04-2012, 11:22 AM   #13
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
If you want a cheap solution then use a roll roofing material and flash the valleys of your dead valley.
Cheap and crappy, just as you asked for.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Nailbags (03-08-2012)
Old 03-04-2012, 11:30 AM   #14
Roll roofing is not even able to work on a 12-1 pitch. 12-2 minumum and even that would be at the limit.
Roll roofing is the lowest of the lows when it comes to roofing.
http://www.atlasroofing.com/tabbed.p...n_url=49&tab=7
Old 03-04-2012, 11:34 AM   #15
Pro Slate Roofer
tinner666's Avatar
Roll roofing serves one purpose in life. To make it's manufacturer money, not to waterproof anything.
The Following 2 Users Say Thank You to tinner666 For This Useful Post:
OldNBroken (03-04-2012), Windows on Wash (03-04-2012)
flat roof trouble winemaker1 Roofing/Siding 10 11-22-2011 01:30 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Shed dormers & existing roof pitch M0hoa5md Building & Construction 8 08-15-2011 05:53 PM
12/12 Roof Pitch - cutting rafters JustAHack Building & Construction 11 10-06-2010 08:43 AM
Metal roof with Fan board insulation, Still have condensation trouble rollenrock33 Roofing/Siding 5 01-29-2010 12:06 PM
